Question about EnGenius EOC-3220 (EOC3220)
There no connection betwen my PC and eoc-322o
Plz help me
  • hiwa Dec 01, 2007
    i lost alot of money by this problem
  • 556 Answers
I have NO EXPERIENCE with this equipment; but have researched this to some degree on the internet. If you are willing to experiment with me we may both learn something. First thing I learned is the difference between ad hoc and infrastructure networks. I have a feeling the default for most wireless routers and wireless adapters is an infrastructure approach. From reading the EEOC-3220 documentation its default is called bridge mode which is an ad hoc network. (this would seem to require reconfiguring your wireless adapter whenever you move from indoors to outdoors -- not desirable.) This can be changed to an infrastructure network by configuring it as an access point which also appears to allow configuration of additional security options including WEP or WPA encryption and MAC checking and could allow hiding the SSID if desired -- all of which apparently could and should match your indoor wireless router. The preferable configuration for the EOC-3220 would be to set an IP address statically (dynamic may be possible) to one valid for the indoor wireless routers subnet and not already used in your indoor wireless router's subnet and disable DHCP on the EOC-3220 and allow your indoor network to control DHCP for the outdoor segment. From what I can tell this configuration should allow the two wireless devices to attach to your PC in a seamless or transparent manner.
Posted on Dec 07, 2007
Brand new electrolux range oven wont work, all that shows on display is F15
F15 means : signal lost between oven relay board & EOC(main computer board)
1. Test the harness and connections from EOC connector P16 to oven relay board J2.
2. Replace the oven relay board.
3. Replace the EOC.1. Test the harness and connections from EOC connector P16 to oven relay board J2.
3. Replace the EOC.
Hope this help. good luck to you.
Feb 07, 2011 | Vacuums
EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Oct 31, 2007 | EnGenius EOC-3220 (EOC3220)
I have EnGenius EOC-3220 (EOC3220) i can not reset with my null serial cable please help me
Depending on the serial cable you have, you may need a modem (crossover) adapter between the cable and the EOC-3220. A good diagnostic is the following: with the EOC-3220 unplugged from power, connect your serial cable and make all the proper baud rate etc. settings in your serial communications program. When it is running, plug the EOC-3220 into power. If you don't see any garbage characters appear on your screen when you plug the power in, your comm program is probably not set up properly. If you see garbage characters but they are not immediately followed by good information from the EOC-3220, then you either need a null modem adapter inline, or you have a dead EOC-3220. If you've never communicated successfully with an EOC-3220 before over the serial channel, the only way to know if you have a dead one is to try again with a known-good one.
Aug 12, 2010 | EnGenius EOC-3220 (EOC3220)
How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type in the URL bar. If you get to, you have a good network connection. If you type in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Mar 13, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
Beeping F11
F11  is a keypad short. This was actually a simple fix when I got into it. Take off the top rear panel. You will need a drill driver or #2 square drive. Once inside: the EOC is held in by 4 screws. Remove those and pull out the EOC.
My diagnosis on the problem is this: The keypad connection to the EOC is the thin plastic serial connector on the top of the unit, looping to the back. What I figure is that this plastic must have the  tendency to warp under the influence of heat and  thus reduces the good connection to the serial input on the EOC. There is a black plastic connection protector on the input side of the serial connector at the EOC. Gently pull this off and pull the serial connector out and give it a good cleaning. Place the serial connector back in the receiver and replace the connection protector back on. ( tricky.  if you have ever built a model or soldered anything you will be fine.)
The serial connection will need some pressure on it  to make a good connection if it is warped. My solution to this was to run a plastic cable tie thru the small holes in the top of the EOC. tighten the cable tie over the serial connector, pressing it to the top of the EOC. This gives it a good pressure on the input pins in the connection input.
Now plug the unit back in. You should have full function of the keypad. If not, it may be another issue with the keypad or EOC.  This was a solution I happened to stumble on and it may not work for everyone but giving it a shot means you might save 170 dollars in parts not including the labor.
Dec 01, 2008 | Ovens
Help with internet conection
If connecting wirelessly are you sure your wireless on/off switch is not accidentally getting turned off and on and do you know how to turn it off and on?
May 22, 2008 | Computers & Internet
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
May 08, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
Change mode
what and how r u doing it?
Dec 05, 2007 | EnGenius EOC-3220 (EOC3220)
Config page
You will always use a straight through.moz-screenshot-1.jpg The default IP for this is you also need to setup your PC with TCP\IP in order to log in. Go to network connections and double click on the  connection for the NIC. high light internet protocol TCP\IP and click properties.moz-screenshot-3.jpg then fill this in device IP then  PC IP then then hit OK.  From there go to your browser and type there is no password or user name set the first time. moz-screenshot-2.jpgmoz-screenshot.jpg
Oct 27, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
169 people viewed this question
Top EnGenius Computers & Internet Experts
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
