speed stream modem lost the internet connection and i have worked with the cable company to determine it is not a line issue. i have also reset, restarted, reconnected everything related to the modem and computer. do you have any sugestions?
1. check ip address in command prompt
2. If unable to find valid ip address , reset ipaddress , in command prompt type ipconfig /release and then ipconfig /renew
3. Ping default gateway in command prompt
4. then ping www.google.com in command
5. If u can ping in command prompt issue with Internet explorer or with Operating system.
6.Try using different browser.
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to...
(More)
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to the laptop, now, the internet light will not come on. If I directly plug the modem to the laptop, all four lights are lit. When I plug in the router only three lights are lit. I have tried everything.
I am trying to use my dsl modem with a wireless g routere but once it is hooked up my modem light...
(More)
I am trying to use my dsl modem with a wireless g routere but once it is hooked up my modem light just continues to blink
no internet light..every thing else working..i reset...unplugged and plugged up every thing the...
(More)
no internet light..every thing else working..i reset...unplugged and plugged up every thing the right way....im thinkin its somthing to do with at&t
internet explorer flashed turning off your comp.to install new up dates when finished no service...
(More)
internet explorer flashed turning off your comp.to install new up dates when finished no service flashed, lights not working on modem are ethernet, internet and aactivity
