Question about GE Monogram® ZMC1095BFBB / ZMC1095WFWW Electric Single Oven
Microwave stopped heating
I have a built-in GE Monogram ZMC1095 series that just stopped heating. The lights/clock etc.. work just no heat. Is this something I can fix on my own?
Thank You,
Steve D
  • 12 more comments
  • Anonymous Jan 06, 2008
    Same problem twice. First time they had to replace a board and it just happened again less than 11 months later.
  • Anonymous Feb 17, 2008
    Microwave oven stopped heating, and started buzzing loudly at the same
    time. Convection oven heating still works. All controls
    still work. Just no microwaves. Unit manufactured Jun 2003,
    failed Jan 2008.
  • Anonymous Aug 23, 2008
    My heating element has gone out 4 times in last three years. It's the Magnetron Tube. GE has finally offered to give us 20% off a replacement oven. Aren't they kind? There is no fix for this. If you replace the tube, it will go out again. Problem now if finding a unit to fit our hole without calling a carpenter.......
  • plops Aug 26, 2008
    My ZMC1095 unit has a defective magnetron after only 18 months.
  • feldmandc Nov 15, 2008
    same problem. Manufacture date January 2004, failed November 2008. this is the 2nd unit with same problem.
  • Anonymous Nov 25, 2008
    Same problem as others - lights, fan (loud noise) and no heat. 2nd time we've repaired this.
  • Anonymous Jan 06, 2009
    We have a GE Monogram ZMC1095SF03 for 2 years and experiencing same problem. Loud noise and no heat! Our solution is to invest in other brand instead of fixing something that you know it will breaks again, unless GE would do some thing about it.
    Myke
    Skokie, IL
    We have a GE Monogram ZMC1095SF03 for 2 years and having same problem. No heat!
    Our solution is to invest in other reliable brand instead of fixing something that you know it will breaks again. Unless GE is doing
    something about it.
    Codi
    Skokie, IL
  • Anonymous Jan 27, 2009
    Same problem as eveyone else...... loud buzzing with no heat. Seems to be a trend for their top of the line microwave!!!!!!
  • Anonymous Jan 28, 2009
    We have a GE Monogram ZMC1095 series microwave that's 1 and 1/2 years old. One day, it just stopped heating and makes a loud noise when you turn it on. It also smells like sometning is burning. Is this the magnetron tube???
  • Anonymous Feb 02, 2009
    Having the same problems. Repaired once but was never really working right. Does anyone know if there were any recalls or comsumer reports on this oven.
    Princeton, NJ
  • Anonymous Feb 08, 2009
    Same issue; burning smell; doesn't heat
  • hera821 Mar 22, 2009
    Same as everyone elses. Did you replace your microwave or just keep fixing?
  • JoeConsumer Mar 30, 2009
    I have the same oven and the same problem. Oven was built and installed in 1999. A few years of use and the magnetron burned out. I had it replaced under the GE warranty program. Service man said new magnetron has a 15 year warranty. Now in 2009 oven failed again. I can probably have the oven repaired for the cost of a service call but I'm seriously considering replacing the unit with something more reliable. Shame on GE for not recalling this poorly designed appliance. I will never buy GE again.
I bought one built in Feb 2005, installed July 2005. Magnetron tube failed Feb 2007 - cost $127 labor to replace. Just failed again Feb 2008 - will cost roughly $135 to replace this time. Not good for such a high end machine!
Posted on Feb 20, 2008
  • louise1410 Nov 06, 2010
    I am now waiting on the 3rd service call for this model....and I know it will be for the same promlem....THE MAGNETRON TUBE!!!. Shame on GE! Also, this is the second home we have had where the builder has used this "upgraded model" for the homes and it was also a problem in the last home......lesson learned. Once again shameon GE.
What is causing my ge single wall oven with built-in microwave oven not heating, only the fan runs?
Is it the microwave or the oven that is not heating? If the microwave is not heating it is more tan likely the magnetron. If the oven is not heating it could be the element or the control board.
Sep 01, 2014 | GE JKP86 Electric Double Oven
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
I have a GE Monogram Built-in Convection Wall Oven (model no. ZEK737WP3WG) and the heating elements have stopped working. The electrical power is working, and the control panel, light, convection fan...
It is possible that a relay on the control board is bad. GE has a relay in the common circuit to the bake and broil element. this has been a problem in a few ovens I have repaired. Check for this it is usually an orange relay on the board.
Apr 27, 2014 | GE Ovens
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
My microwave is working but not generating heat.
Hi well you didn't give the name of the microwave so i cant send you links but from my knowledge when that happens the heating coil burned out my microwave did that a few months ago and i had it replaced and it is regular for it to work its just not generating the heat.
Hope I Helped Please Rate Hight Cause It Helps me
Thanks.... Nick
Apr 26, 2010 | GE Monogram® ZMC1095BFBB /...
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
May 26, 2009 | GE Monogram® ZMC1095BFBB /...
Convection works but Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
duid
try using a voltage stabiliser .it may just solve ur problem..
May 17, 2009 | GE Monogram® ZMC1095BFBB /...
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
GE Monogram® ZMC1095BFBB / ZMC1095WFWW Electric Single Oven Logo
1,263 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
