Question about Toshiba 50A61 50" Rear Projection Television
Remote Control will not work.
Neither the Toshiba CT9946 remote that came with my Toshiba Projection Television model number 50A61 will work. Before I call the repair service, I wanted to know if this is a possible do it yourself fix and if not what should the cost me to fix it.
  • Uhura Dec 02, 2007
    So it is the remotes that are not working and not the remote senor? Because the remote that the Comcast Cable Company provided would also work the Television, but it to does not work. I am sorry if I am repeating myself, I just actually want to understand that it is the remote and not the remote senor. When i spoke with the mobile repairman he said it was the remote senor..so now I totally confused. Thank you GURU for your assistance. And if it is in deed the remote, i willl actually purchase some your company since you are the one who truly solved the issue. I will await your response.
  • 934 Answers
You mean fix the remote - - not worth the cost...
Replace it with a miracle remote http://www.miracleremote.com/
Far less than replacing it with the original and it works everything including access to the service menus.. We have several here in the shop for the various brands and we do have the Toshiba.. It is everyhting it says it is...
Bill
Posted on Dec 01, 2007
  • William Rayburn
    William Rayburn Dec 02, 2007
    Remotes? Your original question referenced only the original Toshiba remote - you've actually tried operating the Tv with a second or possibly third remote??
    I wouldn't attempt to fix the original Toshiba remote if you believe that has failed. Just get a Miracle remote, much cheaper.
    But if you've tried and failed to operate the Tv with a second or third remote and still no luck then it could well be the sensor..
    A sure way to know if the remote(s) are working is to simply test them with an infrared reader, a camcorder or a cheap infrared card... Cards are good for a lifetime and very inexpensive.. Try here: http://www.newremotecontrol.com/IrDet.ht...
    Bill
SOURCE:
Remote won't work.
this would be the IR sensor on the tv that recieves the signal from the remote , but testing of the sensor and components in the circuit should be done.
there will be an Identification number on the sensor and you will have to get that ID and you can either google it or post it here and I will help you find the sensor
Mar 19, 2009 | Toshiba 50A61 50" Rear Projection...
Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
CT9946
The Toshiba codes I have for that remote are
0156 0060 0154 0035
0060 0508 0036 0070
0102 1508 0217 0109
0490 0718 0195 0191
Apr 29, 2008 | Televison & Video
Remote control CT 9954
Hi, here ya go, order part number 23306269 here, www.wehaveparts.com they show several in stock, cost is $34.34 + s&h, good luck, BMW Rider
Jan 04, 2008 | Toshiba 43H70 43" Rear Projection...
Toshiba 53AX61 w/ cracked screen
Lenticular = 23311899 $82.00 NLA
Fresnel = 23311892 $111.00
Protector = 23311859 $82.00
Andrews Electronics, Fox, Herman Electronics
........................................T.
Dec 14, 2007 | Toshiba 53AX61 53" Rear Projection...
Toshiba 50A61..power comes on but no picture or sound
There are fuses in this unit, one could be blown there are also capacitors and a regulator that could be at fault I would suggest U find a repair man in your area if possible to go thru this unit find the fault and repair. It would cost less than to repair than buying a new one.
Jun 16, 2007 | Toshiba 50A61 50" Rear Projection...
Toshiba 50A61 50" Rear Projection Television Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
