Question about Mitsubishi HS-U775 S-VHS VCR
Basic Functions Don't Operate Near End of Tape
My HS-U775 operates well except when the cassette is stopped at any point
near the end of the playing cycle, none of the normal functions will get it going
again. Pushing PLAY, REWIND, FAST FORWARD, etc. are totally inoperative.
If I transfer the cassette to another VCR and rewind back to a point, the U775
will then function normally. If a tape is played non-stop, completely to the end,
it will shift into the rewind mode normally.
Your comments are appreciated.
  • 979 Answers
Defective optical end-of-tape sensor, or alignment of those related component....accordianman
Posted on Feb 15, 2008
SOURCE:
Mitsubishi HS-U775 S-VHS machine has no sound. Playback, rewind, FF, Pause functions work.
Get a VHS head cleaning tape from Walmart and try cleaning the players pickup heads.
Oct 17, 2016 | Mitsubishi HS-U775 S-VHS VCR
How can I stop the cassette deck from stopping play after one second? This happens in both directions on each deck!
The belts on the spindles are worn to the point that it senses the end of the tape and shuts off. Replace the belts.
Oct 04, 2015 | Audio Players & Recorders
Mitsubishi hs m50v
I forget exactly how this goes but there are two posts on either side of the mechanism that read a light signal and a center pole that goes through the round hole on the cassette that gives the light signal (no tape-end of tape). Put a piece of tape on the two side posts and see if that changes anything. Be careful: the tape now knows where end of tape is - do not fast wind/rewind to the end! The loading motor may have failed or a rubber belt has slipped off or is too loose or broken.
Oct 20, 2013 | Mitsubishi HS-U445 VHS VCR
On Kenwood CT 2050, tape speed varies near end of reel and stops prior to end of reel
Many cassette units have trouble handling 120 min tapes. You seem to have taken care of some of the problem areas but in my experience I would suspect the belts have stretched or aged. If this an older deck, the motor may be weakening. It can be the source of the problems you describe
Sep 21, 2012 | Kenwood CT 2050 Stereo Dual Cassette Deck...
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Have Aiwa NSX-V9090 Stereo with jammed cassette. I removed the cassette; however the system still thinks it's in there? When I power up the system it tries to play the tape the stops. I am not able to load...
Check with a small torch, to ensure that there is no tape broken arround the pinch roller or head, if there was no tape broken away, between the pinch roller and the cassette head there is a white cassette bar, this may have become bent.
Aug 08, 2009 | Aiwa HS-TX426 Personal Cassette Player
Technics 373 Dual Cassette - Playback Stops
Suggest having a good clean and replace belts. If it stops around halfway on a C90 or near the end then there's a load problem on the take up reel, before halfway the supply reel.
Dec 13, 2008 | Technics RS-TR373 Single Cassette Deck
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Mitsubishi HS-U775 S-VHS VCR Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
