Question about Philips DSR704
Phillips DSR 704 Problem
DSR Recorder will not boot up properly, have powered down for 2 minutes (more than once) unhooked cales and pulled access card, power back up and get "Powering Up" Screen but never searches for sattellite services and sits on this screen for quite a while. Then will go to "Directv, Just a few more minutes" screen and never goes past it.
  • Robinlbird Dec 06, 2007
    Not to keen on paying $150.00 for a new hard drive to see if it will fix it when I can buy a box off of ebay for less. Is there a way to determine whether it is the hard drive or the unit itself with out just replacing parts?
  • 38 Answers
It could be the hard drive, it could be the unit. The first, and easiest step is to replace the drive.
Posted on Dec 02, 2007
  • Steve Vance Dec 07, 2007
    No, you have to have diags run on the drive and someone who knows what they are looking for to determine if the problem is with the unit.
How to replace drivers side actuator on 03 land rover discovery
Unhook battery
Remove door card torx and Phillips needed
the window frame needs to come out to get clearance
remove the lock bolts in side of door (torx very tight) unplug the loom from the lock and unhook the rod from the inside pull handle
once done the actuator comes out leaving the lock barrel clipped to the door - replace in reverse expecting it to take a while and don't break the plastic clips holding in the actuator rods or they will fall out down the line...
Jun 12, 2014 | 1999 Land Rover Discovery
I am trying to take the passenger door panel off of my 2003 kia spectra however it still seems connected towards the front side of the door but i tryed to removed the two tan screws just free spin i do...
hello,
Disconnect the negative battery cable to prevent shock when handling the door components. Loosen the cable's nut with the pliers and slide it away. Pop off the side-view mirror interior panel with the tweeter on it. Use the door panel trim tool or a flat-bladed tool, such as a putty knife, wrapped in masking tape. Once the panel is off, unplug the speaker connection from behind it. Push the connector's tab in with a flat head screwdriver and pull the connector away. Open the door fully to expose the screw cover on the front part of the door panel. Pry out the screw cover with a flat head screwdriver. Pry out the small centerpiece; not the ring surrounding it. Behind the cover, you'll find a Phillips screw; remove it.
Open the screw cover flap behind the inside door handle. Insert the tip of a flat head screwdriver into the upper-slot; push down to open the flap. Remove the Phillips screw from behind the flap. Pull off the plastic door handle surround piece. Insert the door trim tool behind the panel; pull it back to pull the panel off. Slide the surround piece away from the door panel.
Remove the circular screw cover from the inside door pull storage compartment. Pry it up with the flat head screwdriver. Remove the Phillips screw behind the cover. Remove the screw cover from the rear-edge of the door panel. This cover is similar to the one on the front part of the door panel; pry out the center part, not the ring surrounding it. Remove the Phillips screw behind it.
Remove the two Phillips screws visible along the bottom part of the door panel.
Pry around the perimeter of the door panel with the door trim tool. Pull the tool handle back to pop the door panel clips out. Do this for each side, except for the top. Once the clips are unhooked, the panel is ready for removal.
Gently pull the door panel away from the Optima's door, but only enough to access the area behind it. The connections for the power equipment must be unplugged. Reach around and depress the connection tabs with the tip of the flat head screwdriver; unplug the connection. There are three connections to unplug. Once they are unplugged, pull the door panel away.
Thanks
May 21, 2011 | 2003 Kia Spectra
Kenmore Elegance Vacuum cleaner - power bar not working
The problem almost certainly is that the axle of the brush in your power bar has dirt/fluff in it that is preventing the belt from turning it so that the fuse in the power bar clicks off after 2 or 3 seconds. It is fairly easy to fix. All you will need is a Phillips screwdriver and about 15 minutes. Follow the following steps
1. With the power bar disconnected from the vacuum, turn it upside down and you will see two inset screws at the rear side of the base of the power bar. Unscrew these two screws using your Phillips screwdriver.
2. With the power bar in the same position unlatch the two plastic tabs at the rear of the power par. [It may be useful to flip up the metal bar that you see on the base to use as a handle] On each side of the base you will see an arrow saying insert screwdriver here to release. Insert a screwdriver and lever the plastic of the base slightly apart from the plastic of the side. When you have done this for both sides the base should lift off.
3. Now lift the brush including the two end pieces straight up. It should just slide up. You will need to unhook the drive belt from the brush as you lift it out.
4.Pull of each end piece and clean the dust, lint, hair off the end piece and from inside the end of the brush.
5.Once clean, reinstall the end pieces on the brush. Hook the belt back over the brush to its original position and slide the brush back into the power bar.
6. Reinstall the base by hooking the tabs from the front of the base into the small openings on the power bar.then push the base down until it clicks back into place and the tabs are back in their original position. Reinstall the two screws you removed earlier.
7. The power bar should now work. Good luck.
Mar 05, 2009 | Kenmore 22313 Bagged Canister Vacuum
Dell Inspiron 6400 doesn't boot up properly, and won't turn off.
Try holding down Cntrl-Alt-Delete If that dosen't do it, and it's locked up, you should be able to pull the battery with minimal if any risk Profile settings must be set in administrator mode. Try booting in safe mode
Dec 28, 2008 | Dell Inspiron 6400 Notebook
Unable to connect to Digital satellite receiver
I threw the mitsubishi VHS recorder under a bus, just like ' YOU CHANGE , CHANGE ,CHANGE FOR MY SAKE'S' grandma, and invested in a new DVD recorder, 2 yr g'tee and latest tech. GODDAM A--- well old grandma and anyone or anything else that gets in my manical lust for power. CHANGE EVERYTHING FOR ME, ME ME, ER UM US US US.
THANKS FOR YOUR TIME GUYS.
Aug 20, 2008 | Mitsubishi Televison & Video
Phillips DSR Receiver to 2nd or remote TV
If you are asking if you can use yellow-red-white to one tv and rf coaxial to another tv at the same time to watch the same show, the answer is yes.
Jul 17, 2008 | Philips DSR708 DirecTV DTV Receiver /...
I have a Maytag Neptune Front Loader. I am trying to replace the door seal because it leaks but can not get the machine apart.
For replacing the nuptune boots, I belive these are all of the steps. First, take the 2 phillips screws out of the door hinges. You should be able to lift slightly on the door and pull it towards you to remove it. Also remove the 2 phillips screws straight across from them. This will let your front panel come of (grasp up top and twist slightly to get it off the clips. Lower the front down and you can remove it from the washer and set it aside. Remove the 4 phillips screws from your soap/ fab softner dispenser. Next, remove the 2 5/16 screws that hold the top on to the front of the washer.
To remove the boot, first, pull the front part of the boot towards you. It will actually pull off without much effort. On the bottom (depending on model) there will be a tube at the bottom of the boot that is either stoppered up or connected to a black hose. Squeeze the green clamp to remove the hose if it does have one. To take of the back half of the boot, we're back up top. Lift the top of the machine (you may want someone to hold it or just slide the machine far enough forward the top can stand up by itself). You will see a large spring connected to what looks like a piece of cable coated in clear plastic. Pull the cable towards the front by the spring. It will quickly contract.
Reinstalation time. Take your new boot and install the back half. As you work the boot on, you will see some triangles all the way around to help you line it up correctly. Once it is on, it's time to re-clamp. This is the tough part. Typically what I do, is I make sure the cable is wrapped around the boot from the bottom with the clips at the top. (there is a nice notch for it to fit into) Next I take one side of the spring and attach it to the clip on the cable making sure that the hook side of the spring points up. Now, grab the clip on the cable (without the spring attached) with a pair pf pliers. I use a pair of needle nose pliers to grasp the spring. Now I stretch the two of them together. This will not be easy and the spring will be under some tension. Once the spring is on the clip, lower the lid. (there will be a black wire harness on the right hand side that needs to be tucked back into place for the lid to close properly. Screw the lid down. Re-connect the hose at the bottom of the boot if your machine was equiped with one. Push the front part of your boot back on. Put your door back on the clips where it sits. Lift slightly on the door and swing it closed. Run a test cycle (fill, tumble and drain) while you are standing there to check for leaks. Once you have verified there are no leaks, replace the front panel and your screws. If you run into troubles, message me back.
Jul 04, 2008 | Washing Machines
Sony DSR-1800 Lost Lock
check the condition of the pinch roller. a bad pinch roller can cause this problem - a tape plays for several minutes, then has problems. what happens is the tape slowly moves up or down on the roller instead of traveling in a straight path. this is caused by the roller becoming worn or glazed and not being able to provide traction to pull the tape through.
Sep 24, 2007 | Sony DSR-1800 DV/Mini DV VCR
DirecTV DVR Shuts Down and Re-boots Without Warning
With the DVR up and operating well I would lift up one corner about 1/2 inch and drop it to see if that causes it to malfunction. If it does, then you likely have one or more bad solder connections inside that need repair. If no change is noted, then it could possibly be defective capacitors or a voltage regulator going bad on you. There is also a possibility that it could be a worn recepticle the unit is plugged into, as a power interruption may be all it needs to reboot.
Dec 29, 2006 | Philips DSR708 DirecTV DTV Receiver /...
Camcorder Sony DSR-300 want to burn direct to DVD recorder
You can connect this directly to a DVD recorder. I suggest using S-Video and the two audio channels.
Sep 14, 2005 | Sony Dvcam DSR-300 Camcorder
Philips DSR704 Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
