Microsoft Windows Vista
loadTOCNode(2, 'resolution');
Click StartCollapse this imageExpand this image, and then click All Programs.
Click Accessories, and then click Run.
Type regedit, and then click OK.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
Exit Registry Editor.
Restart the computer.
Microsoft Windows XP
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed,...
(More)
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed, I hear the noise of opening mechanism, but the actual plate doesn't come out. Tried to open HP Solution Center, but got the following message: Parsing error in file C:Program filesHPDigital ImaginginhpqsclocC3.xml
Information on NEW CD's does not download. It used to until my last service update. What have they...
(More)
Information on NEW CD's does not download. It used to until my last service update. What have they done? I'm running Windows Media Player 10 because I can edit DVD & CD files on screen!
my acer 5100 series will burn anyWHERE FROM 2 TO 5 songs then the rest will have errors and i know...
(More)
my acer 5100 series will burn anyWHERE FROM 2 TO 5 songs then the rest will have errors and i know theres nothing wrong with it can u help me jason
