Question about Teac GF-650 Turntable
GF-350 will not record from LP record to cd disc when I press the record button nothing happens                              Brian
Is it possible to fit a new laser unit to my GF350
Posted on Nov 14, 2008
SOURCE:
NEED operators manual for ITRR-501 retro 5 in 1. lost mamual. NEED TO KNOW how to record to CD Disc. Also will it record fro records to disc and record cassett to disk. PLEASE SEND me a manual. OR a zerox...
The unit will record to CD from the turntable, cassette or the AUX port. Place a blank CD-R or CD-RW in the CD tray. (Note: CD-RW discs may not play on other CD players.) Press the Phono, Tape or Aux button to select your audio source for recording. (For Aux, you will need to connect the source device to the AUX port in the back of the ITRR-501.) Wait for the CD disc to load and check for any indicator lights (you should see the "NO TOC" and "CD" or "CD-RW" lights lit). Select your Track increment (or Auto Manual for unattended track formation).Press Record button and the up arrow to adjust the recording level.
If you are recording from an LP, put the tone arm down on the record. For all sources, press Play. Press Stop to end recording or Pause to temporarily break the recording. Press the Track Increment button to advance the track number if you are doing so.
To finalize your CD-R to make it readable on all players: after stopping the recording, press the Finalize button.
The manuals for Innovative Technology products are available here: http://www.ithomeproducts.com/support . The products are listed in alphabetical order. The direct link to the ITRR-501 manual in English is http://www.ithomeproducts.com/sites/default/files/pdf/ITRR-501.pdf .
I hope this helps.
Sep 19, 2011 | Innovative Technology ITRR501 Audio Shelf...
Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Teac GF-350 CD Shelf System
GF-350 will not record in the auxilary mode
TEAC?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Teac-GF-350-manual/id/3841bh048/t/2/
Page 20. What does it say about WHY it won
Mar 12, 2011 | Teac GF-350 CD Shelf System
Sony RCD W500C - How do I copy from a cassette deck to the CD burner - Manual is no help at all!!!!
how to copy cd to cd plus how to get the remote to work then copy cassette to cd ? thank you
Feb 20, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Feb 11, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Procuring the blank audio cds in india for GF 350.
Does this GF 350 turntable use any special CD's ?. please intimate the name and address of the dealer whom whom you purchased this as I also intend to buy this turntable.
Nov 22, 2008 | Teac GF-350 CD Shelf System
RCA CDRW 140 dual deck CD recorder
READY
Place cd you want to copy in tray A (EVEN WHEN YOU WANT TO GET ONE SONG COPIED )
Blank Disc in tray B .
Program tacks in any desired sequence
Press the TIME SET / PROGRAM button on recorder or remote..."WAIT" appears then "01" flashes to let you know the unit is ready for the first track.
Enter the first track you want to program using the numbers buttons on the remote .
or SKIP / SEARCH button on recorder.
When the track flashes PRESS TIME SET / PROGRAM on remote or recorder.
to select it , "OK " appears
HOPE THIS IS HELP YOU NEED >> GOOD LUCK
I WISH MINE WOULD WORK IS DOWN AND OUT !
Oct 08, 2008 | RCA CDRW120 2-Disc CD Recorder
Trying to finalize a cd
Hi, This is just a guess but it may be worth a try. I have heard that Audio CD-Rs, which are the only media this machine will record onto, are famous for being finicky about being played on different kinds of CD readers. My suggestion is that you "rip" the Audio CD-R's content to your computer (in .wav or .MP3 format) and then make a copy of your album onto a reagular CD-R which is more likely to be played on any CD reader. Not sure if this'll work for you but it's worth a shot. Hope this helps.
Jul 31, 2007 | Teac GF-350 CD Shelf System
CD player-recorder won't work
I'm not sure how this site works.  I have the same problem and I'm hoping for an answer. [email protected]
Jul 01, 2007 | Teac GF-350 CD Shelf System
Teac GF-650 Turntable Logo
163 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
