AcerPower 4300 PC Desktop Logo
Anonymous Posted on Aug 17, 2009
Problem whit media player not responds acer power 4300 pentium III RAM 316 XP PROFESIONAL SP3 Media Player 11 30 GB HDD
Anonymous
Level 2:
Sergeant:
  • Expert 239 Answers
  • Posted on Aug 18, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
239
Questions
Helped
73686
Points
727
You need to wait for the system to response.because media player 11 is designed for vista,but it also compatible with xp.but it works good only if u have 512 mb ram as minimum.so it is advisable to upgrade your ram.
Testimonial: "thanks for help"
How do i get rid of xbox and replace my media player
go into control panel under program and feature click xbox and up top uninstall
Windows media player error - "not installed properly and must be reinstalled. Do you want to intall the player from the Microsoft Website?" Media player 11 with Windows XP sp3
you will not be able to upgrade window media only goes to 10 for windows xp. if you are having problems with playback then there are video and audio code packs for windows media that are updated and free.
My computer can not install driver for my go gear sa6185/02
Hi peternsue,
The System requirements for this model are:
• Windows XP (SP2 or above)
• Pentium III 800MHz processor or higher
• 256MB RAM
• 200MB hard disk space
• Internet connection (preferable)
• Microsoft Internet Explorer 6.0 or later
• CD-ROM drive
• USB port
You might have more success downloading Software & Drivers directly from the Support Site:
http://ow.ly/5S9au
Hope this helps! If so, let me know by rating this solution.
What appliance CSI specs
Requirements
  • Windows 2000/XP/Vista (Windows 2000/XP recommended), Windows 7
  • Pentium III 800 MHz or higher (PIV 1.6 GHz or higher recommended)
  • 400 MB free hard drive space for program installation
  • 4 GB+ free hard drive space for video capture and editing
  • 128 MB RAM (512 MB DDR RAM recommended)
  • 16-bit color display at 1024 x 768
  • DirectX 9
  • TV-tuner or video capture board for analog video capture;OHCI-compliant IEEE-1394 card and DV camera for digital video capture
  • Windows Media Player 9.0 recommended
  • 7200 RPM hard drive recommended
Please I need the media player for compaq deskpro pentium 3 what type of media player is required????
Try Windows Media player that comes with your Windows operation system. For Real media, try Real player. Also you can try Media player classic.
Hp invent p dvd940i does not see dvd disk
1. check your system meets the requirements for your device:
• Minimum system requirements: 800 MHz Intel® Pentium® III
processor or equivalent, 1.6 GHz Intel® Pentium® IV processor or
equivalent recommended (Actual drive performance depends on PC
configuration)
• 128 MB RAM (256 MB RAM recommended for video editing)
• 1024 x 768 video resolution with a minimum of 16-bit color required
for DVD authoring and editing
• Video capture: IEEE 1394 interface or analog video capture device
required
• Minimum hard disk space requirements: 1 GB free for included
software installation, 10 GB free for DVD video disc creation (18 GB
free for double layer). Internet connectivity recommended for software
updates
• Operating system compatibility: Microsoft Windows XP/2000
Professional SP4, Windows XP Professional x64 edition, and
Windows Server 2003
2. Have you install the sowftware that came with your device?
3. is your system recognizing the hard drive (go to start>run>type devmgmt.msc and press enter> and look under cd/dvd rom drives... is your device listed? is it showing with a ? unknown device or a ! next to it's name?
a. if the device is not listed chances are you didn't set up the jumper correcly when installing the device or the device may not be powered or there's an issue with the data cable connectd to the device and the motherboard, check your physical setup.
4. check the removable media is in fact compatible with your drive: this is the compatibility list
• Device write media compatibility: CD-R, CD-RW, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, LightScribe CD-R,
LightScribe DVD+R, LightScribe DVD-R, 4.7 GB single-sided/9.4 GB
double-sided DVD-RAM (2.6 GB single-sided/5.2 GB double-sided
media not supported)
• Device read media compatibility: DVD-ROM, DVD+R, DVD+R DL,
DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-Video, 4.7 GB
single-sided/9.4 GB double-sided DVD-RAM (2.6 GB
single-sided/5.2 GB double-sided media not supported), CD-R,
CD-RW, CD-DA, CD Extra, CD-ROM (Mode 1 - Yellow Book),
CD-ROM/XA & CD-I Ready (Mode 2/Form 2 – Green Book),
Photo-CD (single and multi-session), VCD, CD-Text
data taken from http://h20426.www2.hp.com/product/opticaldevices/sg/en/pdf/dvd940i_dataSheet.pdf
2answers
PC dosen't play sounds occasionally
heres a suggestion go back to xp service pack 2. service pack is very easy to use and more compatibility than sp3. right now my 10 pc's are all xp sp2 and they have no problems about the sound.hope that helps
CHARCOIS
3helpful
2answers
Walkman Internal parts
  • General Features:
  • Silver design
  • 1 GB flash memory
  • USB 2.0 interface
  • Holds up to 47 hours of music at ATRAC3plus @ 48 Kbps
  • MP3, ATRACplus, ATRAC3 music playback
  • Supports WMA/WAV format
  • Blue backlit LCD
  • Displays artist, song, album in Traditional Chinese, Simplified Chinese, English and Korean
  • 70 hours playback on one AAA battery (battery not included)
  • Controls:
  • Menu
  • Repeat mode
  • Track repeat
  • Repeat/sound
  • Dimensions:
  • 2.21-inches in diameter (approximate)
  • Weighs under one ounce
  • Regulatory Approvals:
  • FCC
Package Includes:
  • Sony NW-E107 1 GB Network Walkman MP3 Player
  • Quick Start
  • SonicStage CD
  • Earphones
  • USB cable
Additional Information:
  • Notes:
  • Model: NW-E107
  • Product Requirements:
  • Pentium III 450 MHz processor or higher
  • Windows 98SE/ME/2000/XP Home/XP Professional/XP Media Center
  • 128 MB RAM
  • 200 MB free hard drive space
  • 16-bit 800 x 600 color monitor or higher
  • CD-ROM drive
  • USB port
  • AAA battery
4helpful
3answers
WINDOWS MEDIA PLAYER NOT RESPONDING..
Windows Media Player in this case has a script error that causes it not to respond on any OS platform that has yet to be fixed by updates. I have currently updated it to its fullest and it refuses to respond properly on windows xp, let alone beta versions of windows like windows 7. My suggestion is forget windows media player 11 and go download VLC player which plays more things off the bat anyways. Its free and easy and small. There is also any number of other media players like Realplayer, Quicktime, or Windows Media Player Classic.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
