Question about Panasonic KX-T7730 Corded Phone
Incom calls There is a botton y our panasonic KX-T7730 FWD/DND. our problem is that all the incmos calls are submitted to the fax machine and we are not able to answer them could you hel us.
    Scholar:
  • 146 Answers
Check the user manual under "clearing setting" athis should clear any programmed settings, also check "call forwarding and DND ( this the FWD/DND button you refer to ) here is the link to the manual http://www.westlakecom.com/KXT7700-User-Guide.pdf
Posted on Jan 09, 2008
How to remove FWD/DND FROM A PANASONIC KX-T7030X PHONE
Press intercom button
dial *71
choose the call forwarding type to cancel as follows
dial 0 for internal and external calls
dial 1 for external calls only
dial 2 for internal calls only
dial 0 to cancel call forwarding
press speaker to end
Jan 18, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic Digital Model KX-T723OE The key FWD/DND
I'm guessing that you didn't mention that the phone doesn't work, it must be in FWD mode. You can cancel CF, or get someone to go into 990 area 9 bit 3&4 and reverse the bits so it will be solid on FWD and flashing on DND.
Carl
Nov 03, 2010 | Panasonic KX-T7730 Corded Phone
I have an old model of Panasonic PBX system Model D816. I am connecting the main telephone device Panasonix KX-T7730 to Ext. No. 1, this main telephone device has no line and the FWD/DND button light is...
What are the other phones? a 7730 is an analog PITS phone and requires 4 wires to make it work. If you connect it to a digital jack, the data lets it indicate key functions, but there is no voice, and that sounds like what you have. Try taking a 4 pin base cord and plugging directly into port 1 of the 816 and see if everything works. If it does, you have your answer.
In passing, the FWD/DND light will flash if there's a forward or DND condition on the phone. Dialing 7100# from the intercom will clear all FWD/DND conditions, as will pressing the button until nothing lights.
Your delephone reference doesn't mean anything to me.
Carl
Sep 05, 2010 | Panasonic KX-T7730 Corded Phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
Zero Rings during meetings
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Diverting Calls back
If you set call forward all calls then lift your handset press the FWD/DND button, dial 0 , you should get a tone, then hang up. If you set Follow Me then dial 8 and your extension number instead of the 0 . Good Luck. ....Mike
Aug 08, 2008 | Panasonic KX-T7633 Corded Phone
Call forwarding
Lift the handset, press the FWD/DND button, dial 2 and the extension you want your calls to forward to, you should get a comformation tone, hang up the handset.
Cancel the fordwarding by lifting the handset, press the FWD/DND button, dial 0 , get tone, hang up.
Good Luck
Jul 30, 2008 | Panasonic KX-T7730 Corded Phone
CALL FORWARD
hi prabipm,
just follow this instruction.
1.lift hand set or press sp-phone
2.press fwd/dnd botton
3.press 0 and # sign
hope this help...
Jul 23, 2008 | Panasonic KX-T7730 Corded Phone
Cacelling forward
To remove forwarding, lift your handset, push the FWD/DND key and dial 0. Here is the quick manual for that model - http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Feb 03, 2008 | Panasonic KX-T7730 Corded Phone
Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
Jan 17, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
628 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
