Altec Lansing ATP 3W Computer Speakers Logo
Posted on Dec 01, 2007
Altec Lansing ATP 3W Computer speakers
The volume varies while listening to music or playing game..any ideas? ty
  • jim0000 Dec 08, 2007
    if I find a solution I will post it..jim0000
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 05, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
157
Points
The issue seems to be of the volume knob...i had similar issues and had to replace the knob to solve.....
Anonymous
Level 1:
  • Posted on Dec 08, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
157
Points
I am also experiencing the same problem as yours...
Where im going to find connectors of atp3
Altec Lansing ATP 3 has 7 pin mini-DIN connector for Right Satellite. You will find that at electronic hardware store. WebRepOverall ratingThis site has no rating(not enough votes)
I need a software so i can use my new altec lansing atp3. i lost my cd.. please help.
According to the manufacturers site these speakers are plug n play so you shouldn't need drivers. What sort of software do you require?
1helpful
How i find driver to ATO3 ALTEC LANSING, i have windoes 7
Hi there bud ,. Windows 7 Should automaticaly update too the latest drivers , otherwise try google . Altec Lnsing Drivers and you should find it..
Happy new year bud
1helpful
My altec lansing ATP3 right satellite speaker cannot operate...
Speaker is bad or the cable may have come loose. Has it been knocked around? If so it may have pulled the cable loose inside the speaker, try playing a song and wiggle the wire and push the wire in gently to see if it starts to play if it does you have found your problem. If not then the speaker is bad and I don't remember if you can pull it apart and buy a new speaker to install in it. Thanks for using Fix-ya and if this helps please rate this free question.
Avid101
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Altec Lansing ATP3
there is a lose connection near the main speaker .When i move it sound stops
WOOFER SOUNDING BAD ON CERTAIN BASS FREQUENCIES
Try a software solution- download an audie editor like Audacity. The fault sound like a malfunction in the speaker unit ,which is not servicable.
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
