Panasonic DMR-ES30VS DVD Recorder / VCR Combo
Problem for Panasonic DMR-ES30VS DVD Recorder / VCR Combo
How to get all freeview channels
By david151237 on Aug 17, 2009
how to get all freeview channels-all i get is the first 5 channels
Comments:
Aug 20, 2009
- to pauldonp i have a panasonic dmr-es30v. on autosetup it lists only 1-5 channels. but with a digital topbox and my pc i should be getting 31 channels. david151237
Clarification Request
Posted by pauldonp on Aug 17, 2009
hi, are the other channels listed and what is the exact make and model number
Solution #1
posted on Aug 22, 2009
Not Rated)
pauldonp
Rank: Guru
Rating: 88%, 1310 votes
Hi, sorry my reply has been a while the net has been down in my area and i couldnt get any signal so i appologise.
Ive been looking at your product and it isnt a freeview recorder its a dvd recorder so it wont pick up the free view channels itself.
What you need to do is this:
If you have a free view set top box then instead of plugging this freeview set top box into your telly via the scart lead you need to plug this into your dvd recorder then if you wanted to record anything of free view you need to select either av or source on the dvd recorder, this will then pick up the signal from the free view box allowing you to record from it.
Your dvd recorder is not made to pick up free view channels so will only pick up the terestial channels ie 1-5
so you need to plug your free view box into the dvd recorder via either scart lead or another source.
Then on your dvd recorder remote you need to select av or source depnding on your remote it wont be a channel ie 0-9 it will be coming from an external source so its either av or source button once you have pressed this you should now see whats on the free view box. Next select on the free view box what you want to record and leave the free view box on this channel.
Now you can use your dvd recorder to record from the free view box via the scart lead so as long as you select the right source ie av channel you will then see the free view channels
Your dvd recorder wont pick up any free view channels on it own so as long as your free view is connected to your dvd recorder you can then record from it but you change the channels on your free view not on your dvd as your dvd rec will only pick up 1-5 so picking av should let you pick up the free view channels.
Let me know how you get on ok or if you need further assistance ok
Was this helpful?
Yes
No
Solution #2
posted on Aug 17, 2009
Not Rated)
MNfisherman
Rank: Wiz  Panasonic Televisions & Videos  Expert
Rating: 85%, 2858 votes
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Comments:
Aug 20, 2009
- See if you have an "autoprogram" feature in your settings menu, If you are able to access autoprogram feature, it will scan all available channels.
Was this helpful?
Yes
No
Popular Solutions for Panasonic DMR-ES30VS DVD
Questions and Unsolved Problems for Panasonic DMR-ES30VS DVD
Do you recommend Panasonic DMR-ES30VS DVD Recorder / VCR Combo?
Answer
Answer
Panasonic DMR-ES30V plays VHS tapes but does not record from a TV program. After trying to record... (More)
Answer
For no apparent reason the DVD recorder will not read disks.
Answer
trying to find what DVDRAM disks work with this machine, says it does not take 2-3X speed disks. on... (More)
Answer
when playing a dvd on my player to view on tv a sign bitrate is permanently on screen how can I get... (More)
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in Boardman, OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
