Question about Goodman GMS90703BXA Heater
GMPN 120-5 FURNACE
EVERY THING COMES ON PROPERLY. THEN RUNS FOR BOUT 20 SECS. THEN REPEATS .
  • plumber1 Dec 10, 2007
    I just installed new goodman furnace it will go thru a short cycle then stop before igniter can come on (led) indacates polarity switch
    Sergeant:
  • 288 Answers
If you want some help on this I will need some more info. Does the unit shut off completely? does the fan run after the burner shut off, or is off simultaneously? do you have a digital thermostat or the old type?
Posted on Dec 05, 2007
SOURCE:
Goodman GMT045-3A Furnace. Furnace flue fan always on, glow plug hot, gas ignited, on for 20-30 seconds, click is heard, flame off, glow plug cools. Then cycle repeats over and over again. Sometimes...
Check filter to see if it is plugged. Has someone installed a new thermostat? If so, it may not have been installed properly. Sand off sensor to make it shiny, and be sure all supply and return registers are uncovered.
Jan 03, 2011 | Heating & Cooling
My Gibson Furnace clicks on but no heat comes out.
After four years I do not thing you have an effective warranty even if the company still in business. you need to open it first and clean it from any builod up dust and check the switch to see if it is working (thermostate)
Nov 08, 2009 | Heating & Cooling
GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Oct 07, 2009 | Goodman Heating & Cooling
GMPN goodman furnace: Water leaks from the base.
Check the drain tubes inside the furnace. There may be a loose connection or a split tube.
The unit could also leak from the gasket between the secondary heat exchanger and the vent fan housing. The secondary heat exchanger ould also be leaking or cracked.
Hope this helps.
Matt
Jan 08, 2009 | Heating & Cooling
Erratic goodman GMPN 100-4
sound like you have a bad fan motor
Dec 04, 2008 | Goodman CPLE24-1 Air Conditioner
I have a gmpn-80 janitrol 90% eff gas furnace,it is only 15 months old,my condisation tray is melting and cracked do to heat in which case leaks water all over....why would this be happening?
Most likely the cause is that the furnace is firing too hot. When a furnace is installed and set up, the manifold gas pressure and fan speed has to be set by the technician so that the temperature rise through the furnace is a maximum of 50 deg F (i.e. if air enters the furnace at 68 deg F it come out no hotter than 118). The target temperature rise on any gas furnace is anywhere between 30 and 50 deg F. If the furnace runs too hot, either the manifold gas pressure must be turned down or the fan speed must be turned up to keep in this range.
Jun 28, 2008 | Heating & Cooling
No heat, trouble shooting light has continious flash.
Try replacing the filter. Low air flow will allow the furnace to overheat. Sounds like a simple answer. Wish I had tried it before buying a flame sensor and controller. Live and learn I guess.
Nov 16, 2006 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
517 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
