Question about Dishwashers
Suds and water staying in Whirlpool Quiet Partner III
I have noticed that suds have been staying in the bottom of the dishwasher the last 3 times it was used. Yesterday, I went into the kitchen and discovered that the dishwasher was leaking suds and water. I tried to running a rinse cycle and draining and the problem continues. The unit is only a year and a half old. Is this something we can fix ourselves?
  • 2 more comments
  • afrankl1 Feb 13, 2008
    We just started having the same problem with our Quiet Partner III today. Our machine is about 3 1\2 years old. We thought it might be sink water backwashing into the dishwasher??? I noticed our exterior unit suds after I washed an extra set of dishes in the sink in sudsy water and then lifted the stopper on the sink for the sink water to drain.
  • dfulmer Feb 21, 2008
    I too have a problem with our Whirlpool Quiet Partner III dishwasher. Water is not draining from the washer and is standing in the bottom, not a little, but allot. Not sure where the drain air gap is, should that be a possible reason. We purchased the home a couple years back and inherited the appliances. Does this dishwasher have a history of issues? Any assistance would be appreciated. I can be reached at the following -
    Thank You - David
  • kindofblue76 Jun 15, 2008
    I am having the exact same problem. And it just started today. I had suds all over my floor and nothing I can do (running a drain cycle or basic rinse cycle) will clear the water and suds left standing in the bottom of the dishwasher. Don't want to have to call a plumber if I don't have to so any advice would be much appreciated.
    Thanks in advance.
  • krispi Mar 19, 2009
    Same problem. Mine is 3 years old and is leaving water at the bottom the last few cycles. Any solution out there? I really don't want to have to pay for a repair trip charge.
I believe you may be over sudsing, Try a few cycles with vinegar and no soap. Do not use dishwashing soap at any time ever. See if the vinegar trick helps...helijm
Posted on Aug 20, 2009
Any luck, I have the same machine and problem.
Posted on Jan 24, 2008
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwasher is not getting dishes clean. Water is
follow this link:
that guy gave me some good advice!
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
New Quiet Partner 2 doesn't drain at end of cycle.. how to fix?
May be that there was a little regular soap or something put in that made it suds up causing it not to drain. Vegetable oil poured into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
1,187 people viewed this question
Top Dishwashers Experts
