Question about Jensen Q2049J 20" TV
Cannot use remote
I have password protected the child guard and can only watch up to PG programs. The remote has stopped working and I tried 5 generic program it yourself remotes, including one by Jensen and none work.
Is there a way to reset the TV so I can watch all TV programs?
Thanks
corlando52@att.net
  • corlando52 Jul 08, 2008
    I had to order a new remote directly from Jensen that was matched to the TV. It works fine, but was about $50. None of the generic remotes work.
  • 54 Answers
Try using the guide that came with this product, if you dont have one, try going to a local store that sells your product.
Posted on Jan 12, 2009
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
Nov 24, 2012 | Hardware & Accessories
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
No remote and the child lock is on. Can't play dvds and we have no kids.
Get a universal remote and program it for your TV and other devices. Then go into settings and change the child guard setting.
May 19, 2011 | Televison & Video
How do i unblock the channels, no remote
Try this:
On Remote Press Channel Up And Volume Down At The Same Time For 5 Seconds. Then Enter 0000 As Your New Password.
Oct 24, 2009 | Televison & Video
Child can go onto the internet without supervision
you need to set up a password on the wireless router then you can keep people out of your network.
Dec 10, 2008 | Sony PlayStation Portable (PSP) Console
WILL NOT ALLOW ME TO WATCH ANY CHANNELS
If you are on a protected channel where you are getting the "Protected Program by TV-etc" you have to get out of that channel and go to a channel that is not protected. That will allow you to hit your "Menu" button and access the V-Chip settings on your TV. Depending on the type of TV you have, you may end up using your Vol Up button as a sort of "Enter" button. Hope that helps!
May 12, 2008 | Symphonic ST420FF 20" TV
Jensen Q2049J 20" TV Logo
119 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
