Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic 47 HDTV blue looks green
Everything is good with TV, but all shades of blue appear green. Picture is fine, just what is supppose to be blue is actually green. I was watch North Carolina basketball game and they were wearing baby blue jerseys and it looked like green. Whats the problem? Thanks so much.
  • 934 Answers
What you have there is referred to as white balance... The Overall White Balance May Suddenly Change And Become More Red, Green, Or Blue Depending On Which Crt Has Been Affected. During Turn Off A Crt Might Arc, Causing D304 (Red), D331 (Green) D361 (Blue) Damage And Leak Changing Cutoff Levels. Replace Diodes With Panasonic Kit # Txask02gser. Kit Contains 3 Diodes And 3 100k Resistors. Install New Diode And Resistor In Series In Place Of Old Diode. Install Annode In Crt Socket Where The Old Annode Was. Then Connect Resistor To Cathode End, Other End Of Resistor Goes Into Pcb Where The Old Diode Cathode Was.
A job like this in my shop we charge $280.00 dollars plus tax which includes the kit... Also a pickup/delivery fee if we have to go and get the unit...
Bill
Posted on Dec 01, 2007
SOURCE:
I have everything in blue. All colors are a shade of blue. The picture is bright clear but everything is shaded blue. Tried new HDMI and new sources but still every thing is in the blue spectrum. ...
The LCD chips in your TV set burned out the only one working is the blue chip that is the reason everything is that color.
You need to replace the optical block in that TV set to fix the problem.
This part runs from $150.00 - $250.00
I hope my answer was helpful :)
Oct 09, 2013 | Panasonic PT-60LC14 60" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
I have a Panasonic PT-47WX53, this morning when i went to turn the TV on the picture was not align. The red and blue look aligned but not the green, i opened the back and when I coved the green light the...
This kind of problem occurs due to failure of convergence output chips located on main circuit board of tv and replacement of convergence output chips will hopefully solve your tv problem.
Soldering work is involve to replace these two chips so have local tv repairman for that job if you are not familiar doing so.
Thanks.
Jun 29, 2011 | Panasonic PT-47WX53 47" Rear Projection...
To much blue shade in picture
You may need to replace your STK chips in your convergence board. I just replaced mine due to ghosting. Seems to me asd anything that affects your picture quality is caused by bad STK chips. I purchased mine on ebay with a soldering iron solder and a solder ****** braid and paid 30.00 which includes shipping! Took less than an hour. The auction was for the STK392-010 but they had mentioned a 040 chip in the listing in error and sent me both sets. The STK392-040 is a better chip and works perfectly with my HC-P4752W. I had never soldered an electronic part in my life. I am an electrician and a plumber and master install tech. buy the chips. while they are being shipped to you, look at YOUTUBE for videos of soldering and desoldering using braid. You will get a good idea at what you need to do to fix tv! Also look for anything related to the convergence board for this model on YOUTUBE. Sorry so long but want to help as much as I can!
Dec 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Sonia bravia lcd digital tv with colour problems
Hi sheridamiddl, I will be happy to help. i few things I would like you to try.
  1. From the menu set the TV back to default options.
  2. Check and see if you have the same problem from different inputs, try watching a dvd or game console.
  3. Unplug the TV for a couple of hours and let it reset.
Let me know if this works and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 16, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
No picture
This set is a projection tv with 3 tubes red,green,blue more then likely 1200pf 2kvolt capacitor,hori output transistor.
Dec 06, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
GREEN DOTS ON SCREEN PANASONIC PROJECTION HDTV 1080I
Ah, big no-no.
This is the result of the coloring being pulled to the front of the screen.
This is caused by magnets. Anything magnetic will cause this, even a small one.
Hopefully you have warrenty, this is pretty expensive to replace.
Jan 02, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
