Question about Bose 901 EQ1915 Home Equalizer
901 EQ1915 i dont have a bose eq but i was wandering if i could use another eq to help run my 901
    Brigadier General:
  • 8,546 Answers
No. You may think you're doing it with the first solution, but the EQ curves introduced by the Bose Active EQ are extremely steep at the extremes. One could just as easily advise that the RIAA phono EQ curve (look it up) could be simulated through an external EQ, but why would you want to try? The best you would come up with is a ballpark match. Don't we really strive for accuracy?
Bose 901's employ 9 full-range, 4"-diameter drivers in each cabinet, hence there are no tweeters, no woofers and no internal crossovers. You can probably imagine how much EQ it would take to make a full-range driver, with its inherent limited voice coil travel and steep roll-off at the extremes, respond as if it was, say a 12-inch woofer, or a tiny dome super-tweeter.
Every series of Bose 901 that came out had its own specific matched series of Active EQ to compensate electronically for the natural limitations of the individual drivers. I imagine there were a lot of major simlarities from one to the next and that you would not be too far off the mark to mix a Series-IV EQ, for example, with a Series-V speaker pair, but I really doubt you're going to dial in the same curves with a manually adjusted equalizer without some specs as a guide.
Try to find the correct Active EQ on eBay. You’ll be much happier with the results.
Posted on Nov 30, 2009
  • 1,512 Answers
The original eq provided a bass boost about 120hz treble boost starting at about 5k. you could use a half octave equaliser to the same effect. like a big fat loudness control :)
Posted on Dec 14, 2007
How do I connect my bose equalizer to my pioneer amplifier
The manual is at Bose.com.
In any question regarding connections the exact models of all parts in the scenario should be defined.
"Pioneer amplifier" is not unique nor revealing. Integrated amplifer? Power amp? Tape Loops available? Pre-Outs? What's involved as a preamp?
The key thing to know is that any amplifier channels driving 901's must not drive other speakers as the Active EQ severely modifies the Line Level source input. If the EQ (or any sound processor) is used in a Tape Loop on a modern multichannel digital-audio-capable AVR, ONLY 2-channel analog sources will function when the Tape Loop is engaged; and all downstream speakers will be affected by the processing. That's par for the AVR course.
Bose 901 use in multichannel applications (which I have) will require access to Pre-Amp outputs for the chosen channels (likely the Front) and you will need to get a separate amp for the 901's, placing the EQ in series with the chosen amplifier. I currently drive mine with a Carver MT-200T.
Sep 20, 2011 | Bose 901 EQ1915 Home Equalizer
Sansui 8900 zdb to connect to pioneer rg2 dynamic processer then to bose 901 active equallizer. what is the proper method to connect these?
Referring to the picture and remembering that ONLY 901's can run off of any particular amplifier.
http://vintageelectronics.betamaxcollectors.com/sansuistereoreceivermodel8900zdb.html
I can't make out the label for tape copying. You want the 901 EQ to be the "TO" when 'copy' is selected. That way it's EQ will not affect your taping to the upstream deck or processor. Or in your case, you want the RG-1 to proceess the audio first, not after the 901 EQ changes it.
http://www.classicaudio.com/forsale/pio/RG1.html
In to Outs. Both the RG-1 and the 901 Active EQ have facilities for attaching other processors or tape deck(s) within their tape loops. In a pinch you could daisy-chain the RG-1 in front of the Bose 901 EQ on a single tape loop to free up the other one.
Go to Bose.com for the manual and specific pictures of the hook-up.
Sep 05, 2011 | Audio Players & Recorders
PROBLEM CONNECTION SONY STR-DH800 TO BOSE 901 PASSIVE EQUALIZER
on my sony STR-DH800 only center speaker is heard the side speakers is very very low
Feb 18, 2010 | Bose 901 EQ1915 Home Equalizer
Will a Luxman R-117 receiver run my Bose 901's through the required equalizer?
Yes, connect the Active EQ into one of the abundant tape loops and set the receiver to monitor that one constantly. Or place it between the Pre Out and Main In's. What you don't want to do is have the Active EQ in front of any actual tape decks attached to the Luxman as it would affect their audio. Yeah, pre/main is the best place.
Jan 31, 2010 | Bose 901 EQ1915 Home Equalizer
Pioneer SX2300 with no radio recption
try the pioneer in another place and move the antenna to other direction until you receive a signal.
Dec 02, 2009 | Bose 901 EQ1915 Home Equalizer
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 and Tube amp
Yes! When the Bose ~Steve901 first came out that was the amplifier of choice -like the McIntosh classic amps. The 901s have their own equalizer as that speaker system is a phased-array,
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
Bose 901
1-record out from receiver to to equalizer in.
2-equalizer out to tape pb in receiver.
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
Bose 901 EQ1915 Home Equalizer Logo
429 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
