Question about GE 24 in. GSD3210Z Built-in Dishwasher
Soap does not desolve
I am have a problem with my dishwasher where the soap does not desolve. We use a liquid soap and have tried tablets. The main latch door does open during the cycles but when everything is finished and we open the dishwasher either the tablet is laying at the bottom of the dishwasher or the liquid soap is running down the side of the dishwasher. Where do I start troubleshooting this one at?
  • 4 more comments
  • Anonymous Feb 12, 2008
    This
  • debbiedoodle Feb 21, 2008
    I have the same problem. My dishwasher is only 13 months old and this just started happening.
  • Anonymous May 27, 2008
  • jrw196 Jul 22, 2008
    The powder gets stuck in the tray and isnt dispersed throughout the dishwasher.
  • zooj44 Feb 04, 2009
    same problem with soap, maytage mdb4650AWB, any adivce would be greatly appreciated.
  • ktsmith May 11, 2010
    I have the same problem, how do I fix it so my soap will dissolve?
I put the wrong dishwasher on my last post.
Posted on Nov 14, 2008
2 Suggested Answers
  • 1314 Answers
SOURCE: Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Posted on Jan 31, 2008
I have a Dishlex Global 300 and sometimes the detergent was not empying out when i did a wash cycle (seems that the top rack would prevent the door of the detergent holder to open fully) I just purchased...
it could be your water preasure or the water is hard,,,but like with most dish washers the tablets dont desolve all the way,,,you need more of a liquid soap type of a cleaner
Feb 19, 2011 | Dishwashers
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
Do I use soap?
Yes,dishwasher liquid,tablets or powder. Not dish soap like Dawn,Palmolive etc.
Sep 29, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Not rinsing soap still on dishes
try washing the dish washer out with a good drain unblocker the system gets cloated up with grease, then use a dishwasher salt with the washes this will help to remove the suds ets, most dishwashes have a compartment to put either liquid or solid dishwash aid in try a different aid, also if you use tablet form i desolve it first in hot water in a small container
then place that into the dishwaser on the lower shelf, that helps
Aug 16, 2009 | Dishwashers
Soap dispenser drops soap out and tablet does not disolve.
use liquid soap ...those tablets are less messy but they don't work very well ....and make sure to use a dry agent like "jet dry"
Jul 25, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
I have a kenmore dishwasher. the soap dispenser lid was not opening and releasing the soap, now the lid is opening but it's leaving the soap in the dipenser. have used the pellets that contains the liquid...
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Apr 09, 2008 | Dishwashers
Jan 31, 2008 | GE 24 in. GSD3210Z Built-in Dishwasher
check that the spray arms are turning and that the holes in them are not clogged, if you line them up pointing towards the front let the machine fill then as it starts to wash open the door and you should see the arms slowing down, if they are okay then check the water level which should just lap the filter at the bottom
Jan 07, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
GE 24 in. GSD3210Z Built-in Dishwasher Logo
357 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
