Question about Wacom Intuos3 Graphic Tablet
Water problems I seem to have dropped a bit of water on my Wacom Intuos3 Graphic Tablet and now it doesnt work, yes I know a bit clumsy on my party but I don´t think it´s completly lost, is there anything I can do to fix it?
  • 4 more comments
  • Anonymous May 12, 2008
    I have exactly the same problem, tiny drop of water, completely not working....also i refuse to take a tissue to my Intous - there must be a better way.
    could it dry out on it's own and be OK...Is that wishful thinking?
    What shall I do?
  • Anonymous Aug 26, 2008
    Someone spilled a cup of coffee on my Intuous3 and now it does not work - the power LED does not even shine. I have left it to dry out and opened it up (as much as I was able to) to clean it, but it seems to have no power now. I assume the liquid messed up a power component inside it. :(
  • smoochie5555 Mar 16, 2009
    my cat barfed on my wacom tablet express keys while i was on vacation. now it not working.
    is there any place that will fix it?
    will the company repair it?
    does disassembling and drying out really work?
    thanks!!!!!!!!!
  • Anonymous Apr 25, 2009
    I have taken my wacom apart and cannot remeber where the white sheet goes... at the very back or between the meatl sheet and the circuit board? Can any one help
  • Anonymous May 22, 2009
    I spilled water on my tablet, but when i opened it i torn the copper strip....now it's not working. the power led is on tho... do you think wacom is going to fix it (still under warranty)?
  • tritrouble May 22, 2009
    I spilled water on my tablet, but when i opened it i torn the copperstrip....now it's not working. the power led is on tho... do you thinkwacom is going to fix it (still under warranty)?
DIE DIE!
Posted on Aug 28, 2008
  • 363 Answers
I would completely disassemble it and dry it out with tissue and a hair dryer.
Posted on Dec 01, 2007
  • 4 Answers
Noooooooooooooo! me too :'(
- hang on!
I opened it up (almost destroyed it in the process) dried it out with a hairdryer for some minutes and it works great!
Be VERY careful when opening it because there's a short and fragile copper ribbon connecting the circuit board (fixed to the top piece) to a loose shield plate at the back. It's connections are on the side of where USB cable goes into the the tablet so open it from the other side in a tilting way, just dont try and pull the cable side of the tablet away from its other half. There are clips under the tablet you can use after undoing the screws to split the two pieces.
Posted on Mar 25, 2009
SOURCE:
Wacom Intuos 3 problems
Hi Bengref
Just talked to WACOM USA about a similar (but not exactly the same) problem with my Intuos 3. One of their procedures was;
go to the ALL Programs directory,
go to the the WACOM TABLET directory
open the WACOM Tablet Properties window
click on the "About" button
while holding down the CTRL key, click on the "Diagnose" button
click on the "recalibrate" button
Another procedure
go to the All Programs Directory
go to the WACOM Tablet Directory
click on the :WACOM Table Preference File Utility"
Under "My Preferences" click on remove
Good Luck
BobS
May 19, 2010 | Wacom Intuos3 Graphic Tablet
My Wacom Tablet won't recognize the pen.
you have to install the pen on the CD you have from the box you got it in
Apr 21, 2010 | Wacom Intuos3 Graphic Tablet
Intuos3 and Mac OS X (10.6)- No preferences menu/program/software
hello, just go on the wacom site and download the newest drive for mac os x, i was having similar problems, but now everything's fixed and it's working fine!
go to the following link,
http://www.wacom.com/downloads/driver-detail.php?id=215
Jan 03, 2010 | Wacom Intuos3 Graphic Tablet
I can't install my Intuos3 onto Vista
I don't think there are any programs for the Wacom. I don't see any on my computer. Open photoshop and see if the tablet works in there.
Nov 30, 2009 | Wacom Intuos3 Graphic Tablet
Wacom intuos3 pen is not working
A few hours ago Wacom released a new driver 6.1.2-5 for the Windows 7/Vista/XP operating systems. I was having the same problem. Hopefully this will be a permanent fix!
http://www.wacom.com/downloads/driver-detail.php?id=200
Nov 19, 2009 | Wacom Intuos3 Graphic Tablet
Hello! I own a Intuos3 Wacom tablet and I am having problems with it. My old laptop did not recognize discs, so I installed my tablet using one of the drivers from the download section and it worked just...
I'm getting the same problem - for some reason it's removed all pen pressure sensitivity recognition from the tablet. I'm going to try re-installing the drivers tonight, I'll get back to you if I figure it out.
Oct 03, 2009 | Wacom Intuos3 Graphic Tablet
My Wacom Intuos3 tablet won't switch into pen mode
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
Feb 04, 2009 | Wacom Intuos3 Graphic Tablet
Keeping wacom intuos plugged in
There shouldn't be a problem with keeping it always plugged in.
Jan 25, 2009 | Wacom Intuos3 Graphic Tablet
Installation problem
After much reading and searching and not finding anything I decided just to download a newer driver from their site wacom.com. It worked perfect! So the CD that came with the tablet is probably out dated!
Oct 10, 2008 | Wacom Intuos3 Graphic Tablet
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Jun 23, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Wacom Intuos3 Graphic Tablet Logo
717 people viewed this question
Top Wacom Computers & Internet Experts
jasbo
jasbo
Alun Cox
Vincent G
Vincent G
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
