Question about LG 42LC2D 42 in. LCD HDTV
Dish Network Remote
I have a Vizio P42 and need the DishNetwork remote set up to control the TV. The techie from DishNetwork couldn't solve the problem. Can you help out? I have a list of codes from the internet but they don't work and Vizio is not listed in the DishNetwork manual.
Thanks,
Donna
  • LK26 Feb 11, 2008
    My Dish Network remote will change the channels but will not operate the volume. I receive my local channels via the local cable company. The Dish remote will not switch to T.V. I cannot use the Dish remote to access local channels. Additionally, the remote that came with the Old RCA G26251TN does not work. I cannot find a RCA code that will work with the Dish Network remote or the original remote that came with the T.V. It is unfortunate that the remote problem is not mentioned prior to becoming a dish customer.
  • Anonymous Mar 27, 2014
    REMOTE CODES FOR DISHNETWORK
    Novelist:
  • 148 Answers
Not every remote is capable of controlling every unit via remote codes. however, there is a set up in the manual that takes time to use. basically you will use the output from one remote to establish the same output for the new remote. its a step by step process. try a universal remote such as theater master which allows you to use a computer to control functions by assigning them to certain keys. this will be far easier. the mx700 is a capable unit for complex functions on multiple equipment and has a screen to guide you during actual use as to what each key is going to do. you will set up the specifications yourself, such as channel up or channel down, or menu or guide. you get to use already established key locations or choose from 10 along side the screen to state whatever you want, and then after its set up, those buttons do the work you programmed them to do.
good luck
mark
Posted on Dec 24, 2007
SOURCE:
Quisiera saber codigos para la tv vizio
Hola mi nombre es Kimberly Escobar con DISH Network, sera un placer ayudarle y proveerle la informacion que necesita. Ciertos codigos que pueden ser integrados a un control de DISH Network para que funcione con un televisor Vizio son los siguientes: 627, 505, y 520. el procedimiento a integrar uno de los codigos es el siguiente: oprima el boton de t.v localizado en la parte de arriba en el control por 5 segundos, una vez los botones se iluminen en rojo ingrese uno de los codigos seguido por el signo de numero. Por ejemplo 627#, el boton de t.v debera iluminarce 3 veces. Despues de este procedimiento puede intentar usar el control con la t.v. Tambien puede visitar este link, aqui puede encontrar mas codigos y los pasos a seguir para programar el control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita ayuda adicional me puede contactar directamente a [email protected] Gracias y espero esto le sirva de ayuda.
DISH Network
Kimberly Escobar
[email protected]
Aug 26, 2011 | DISH Network IR Remote Control
What are the vizio tv codes to program my dish network remote controller
Hey perlhoff,I see you need the remote codes for your Vizio TV. The codes are; 627, 505,506, 006, 527, 625, 110, 775, 756, 885, 864, 758, 111, 112 and 000. I will senda link to help with steps to do the Power Scan, http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Jun 10, 2011 | DISH Network Televison & Video
I have vizio tv and i wana use the dish remote for my tv 2 how 2 program?
Hello there! this is Kimberly Escobar with Dish Network customer support, just ran across your post and wanted to provide you with with information that will be helpful to you. To program your remote to your Vizio T.V you can try using some of the codes we have available that help the remote control functions of your T.V itself. For the Vizio brand one of the codes is 505. what you will need to do is press and hold the clear T.V button located on the upper left hand corner of your remote until all the other top buttons begin to light up, once they light up you let go of clear T.V button and enter the number 505 followed by the pound key (#) as soon as you press pound you will see the clear T.V button flash 3 times. You can can your volume or turning off and on the T.V it should work. For further assistance you should also find this link very helpful http://www.dishnetwork.com/SupportSection/remote-setup as well as contacting us directly. Hope this helps!
Jan 24, 2011 | DISH Network IR Remote Control
We just got a new vizio tv and we have all the same receivers. we have a 722 receiver but the ir remote will not work.
Hello Daniel Busa with Dish Network customer service here. Vizio tv's almost always program to 505 so try this code first. To program this hold the clear tv button down for about 4 seconds the other mode buttons will light up. Once they are all lit hit 505 and pound. If that doesn't take care of it use this link:http://www.dishnetwork.com/SupportSection/remote-setup
Dec 25, 2010 | DISH Network IR Remote Control
My friend has a Vizio model E470VA and Dish network. But the Dish remote will not control the volume / mute on the tv reliability. The on/off button works perfectly. Remote has been replaced also...
Hello, my name is Becki Barned, and I am with Dish Network customer service. To program the remote to a Vizio tv, there are a couple approaches that you may take. First is, follow this link: http://www.dishnetwork.com/SupportSection/power-scan-instructions which walks you through it. Or do these steps: 1. Hold down the TV mode button until all mode buttons at the top of the remote light up, then release. 2. Punch in the code 505. 3. Press the pound (#) button on the keypad. Use either of these, and that remote will work great! Just make sure after you get the volume working, that you press the SAT button on the remote! If you have any other questions, blog back, or you can find us on Twitter!!!!
Dec 18, 2010 | DISH Network IR Remote Control
I need remote codes for vizio lcd tv
Hi there, this is Kimberly Escobar with DISH Network. Ran across your post and wanted to provide you with the information you need. some of the codes for a Vizio T.V are 505,671,627, and 766 you can find more information on http://www.dishnetwork.com/SupportSection/remote-setup this link can be very helpful and help you find codes you need for any brand of T.V.
Mar 13, 2010 | DISH Network IR Remote Control
I need the tv code for a 20" vizio tv using a dish network remote from a dvr 522 receiver
Hi here are the codes for Vizio as supplied by dishnetwork
505, 627, 775, 758, 756, 885, 864
Feb 01, 2010 | Zenith ZEN700 Remote Control
Programing Dish Network Remote to control a Vizio Tv.
Try 627 for Vizio TVs - that should work on the Dish remote.
Dec 22, 2008 | DISH Network IR Remote Control
Dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Nov 23, 2008 | DISH Network IR Remote Control
LG 42LC2D 42 in. LCD HDTV Logo
975 people viewed this question
Ekse
