Question about SanDisk Sansa e200 MP3 Player
Sansa not working
How can i fix this problem? wen i connect my sansa to my computer the sansa restarts and when i try to play a song the screen goes blank and then it restarts. also evertime i turn it on the first thing i see is chose a language and it is not storing any radio presets.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
SanDisk freezes when trying to play a song, then it restarts itself.
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works.........Try and drag and drop from your music folder to the media folder on the player make sure usb mode is mtp this will show you all the folders Use your windows explorer for the transfer... much easier.....
Then disconnect from your computer and see if it worked
Hope it does..........Please rate
May 17, 2009 | SanDisk Sansa e260 MP3 Player
Can't add or remove music off my Sansa Rhapsody 2GB
first try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
MP3 not playing the songs and gets restarted
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Oct 15, 2008 | SanDisk Sansa e270 MP3 Player
Sansa Connect Problem
I had the same problem with my Sansa Connect. It refused to start up when connecting to my computer. I think it may have something to do with not refreshing my music every so often. I tried the Recovery Tool, but it did absolutely nothing. Same problem was still there. So, I did a factory reset and it worked. No problems. I would recommend refreshing music regularly to avoid this problem.
Dec 26, 2007 | SanDisk Sansa Connect MP3 Player
Wont play songs
-Tha Mp3 Doctor
Oct 07, 2007 | SanDisk Sansa e200 MP3 Player
Computer won't recognize my mp3 player
you could try to reboot/restart the mp3. you are going to have to erase everything and start new, you may have gotten a bug when you were downloading.
Jun 25, 2007 | SanDisk Sansa e260 MP3 Player
Frozen on refreshing database
-Tha Mp3 Doctor
Apr 18, 2007 | SanDisk Sansa e200 MP3 Player
Doesnt do anything but boot to language screen
wen it freezes just hold the power button for about 15 seconds.
Mar 12, 2007 | SanDisk Sansa e250 MP3 Player
Whattt is going on?
-Tha Mp3 Doctor
Feb 16, 2007 | SanDisk Sansa e250 MP3 Player
Player reads there is song, computer says there isnt&folder problems
I just fixed exactly the same problem, it's a virus that corrupts and blanks songs at random. Do the following: -Back up any songs that AREN'T in the folder with the repeating one or any you cant delete, they likely will have corrupted -Set USB mode to MTP -Plug into computer -Right click on icon and select "format" At this point the screen will display 'writing' until you unplug it. If you dont have the firmware updater, download it! Tell it to update the firmware and it will set up the folder structures for you again. SCAN ANY SONGS YOU BACKED UP FOR VIRUSES!. Dump all your songs back on and you should be OK.
Jan 24, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
