Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Bosch SHY56A05UC/14 How do i install a drain hose into the back of the dishwasher
My bosch dishwasher will not dry the dishes
Posted on Apr 26, 2010
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Posted on Dec 18, 2007
Bosch dishwasher shy56a05uc 14
I would assume it would leave water in the machine. some machines have this as a function. it is used to keep water in the drum to stop items becoming excessively creased. it is mainly used if you are not going to empty the machine for a while. you should be able to press the cancel button again to start the draining process.
Dec 13, 2013 | Dishwashers
Bosch dishwasher model SHY56A05UC/14 door wont latch. It will run but of course water comes out as it is not locked.
That sounds more like a gasket problem then a lock problem. Check the rubber seal on the door for damage. Even a small imperfection in the seal can cause the door to leak even though the lock is engaged.
Or is it that the door just won't close at all? If that's the case, check the locking mechanism to see if there's anything jammed in there. If so, remove it and that may fix the problem.
Jan 01, 2013 | Bosch Dishwashers
Bosch dishwasher model shy56a05uc/14 door wont latch
I tried the various solutions on this site with no success. Finally I wedged it shut with a nice clear plastic door stop. Worked perfect (who cares if people think it looks funny, I am not hand washing and still am not out any extra dollars)
Jan 01, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Jan 29, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
Does nt drain
Check the following to address this issue further.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer or Control board
Replace if defective (note: uncommon problem).
Jun 19, 2009 | Bosch Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Our Bosch dishwasher will not drain. Model number is SHY56A05UC/23. Help!
can you hear humming?try taking out the screen filter and there is a torx screw that you can see, remove the screw and see if there is anything in there when you remove the panel.you will see the drain impeller try turning it by hand. if it is siezed then you will have to replace it.try putting it back together and try it again.
let me know.
Nov 11, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Jan 15, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch SHY56A05UC Drain Pump Replacement
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
Jan 13, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
486 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
