Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Monitor help Hello...I had to install a blank hard drive in my desktop, and since I've done that, my "plug and power" MAG innovision monitor's display is HUGE!! I'm assuming it's b/c my hard drive doesn't have the driver it needs, but I don't recall ever needing one for my bunk hard drive... I've downloaded the driver from this site, but I don't know which files to install...nor do I know my monitor model # (it's a flat panel 19", that I've had since Christmas '04) Thanks!
    Brigadier General:
  • 6,966 Answers
With or without the drivers, you can still try lowering your display properties (resolution and refresh rates) PC side. Should this not be sufficient, please post back the brand/model of your computer or at least the video card that is being used.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 10, 2008
Cant figure out where the power cord goes or even if it has one...
There are several Mag monitors that use external AC adapters that plug into the VGA cable. Look on the blue connector and you should see the hole where the adapter plugs. The adapter is 12v 5 amp such as this one.
Dec 03, 2012 | Mag Innovision InnoVision LT 765S 17" Flat...
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
Nov 13, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
My lt865b doesn't display anything and the display functions of the monitor do not respond at all i love the monitor and need help.After 3hrs use the display starting going all white then blacked out. I...
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Mag Innovision InnoVision LT865s 18" Flat...
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Sep 21, 2009 | Mag Innovision InnoVision LT765 17" Flat...
Does the MAG LT-456s require drivers
Perhaps your screen resolution is set too high. Try using a different display to set your resolution to 800x600, then attach the MAG display. Adjust from there once it is working...
Mar 08, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Mag Innovision 765S Screen Flashes on and off.
It sounds like it is trying to re-synchronize it self and not going back the the default setting. Compare the resolution of the game to your monitor capabilities.
Dec 29, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag innovision LT716s monitor model 700p blank screen
Try to adjust the frequency.
Right click on desktop , properties, (my windows is in portugese. Dont remember the right name) configuration, button "advanced", display.
I hope to help u.
Good luck
Dec 17, 2007 | CTX PL 9 19" CRT Monitor
Power light flashes with no display
That usually means that the connection between the PC and the monitor has been interupted- check that the cable (probably has blue ends) between the two is firmly connected, and power it back up. If that doesn't work, you have one of three problems; a broken VGA cable, a broken monitor, or a broken video card. Finding out which- you'll actually need someone tech-savvy there to help you figure that out. Try plugging the monitor into a different computer. If that fails, use a different VGA cable (cables are pretty cheap at, and if that fails, it's your video card.
May 23, 2007 | Mag Innovision InnoVision 786 PF 17" CRT...
MAG Innovision LT456s monitor power issue.
If you ask them nicely they just might tell you, else it's only $5 for a user manual(sorry no luck online); this link has a picture that maybe shows a power cable going to the bottom right (as you look at it) but it's hard to be sure; this link shows what the power lead should be like - look for a hole that matches; Hope this helps, if not ask again :)
Mar 17, 2007 | Mag Innovision lt456s 14" Flat Panel LCD...
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
60 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
