Question about Kodak Carousel 4400 Slide Projector
No light source through lens
I had a slide stuck and after removing it there is no light going through the lens. Bulb works, mirrors look OK, light seems to be blocked in front of the lens. Also forward/backward buttons not working.
  • DennisWK Dec 10, 2007
    Essentially the same problem with the 4400. It appears that there is a black metal shutter blocking the light path just ahead of the lens, and I can't see any way to drop it.
    Scholar:
  • 33 Answers
The blackout shutter is on a very sensitive "trigger". When the two silver pressure pads that push against a slide inside the gate (aperture) are flat against the gate- that is no slide in place - the pads are linked to the trigger and make the blackout shutter stay up, blocking light from hitting the screen when no slide is in place. When there is a slide, the pads trigger the spring mounted shutter to fall down.
Least likely but possible is that the spring has come off one end of the shutter.If so, disassembly of the projector casing , not the mechanism, will be needed.
Most likely is that the trigger is out of adjustment. It's fairly simple but if you overcompensate and/or don't understand exactly how it works you can end up with the shutter not working at all.If that happens the projector will still work but the light will flash on the screen at each slide change. So whether you want to tackle it will depend on your comfort zone as far as 'fine" adjustments go. If you don't get it right you may have to do some major dissasembly of the projector to get to the mechanism. You will not need to take any part of the mechanism apart however.
Just thought of one other possibility. Look into the side of the gate where the slides fall into, with a strong flashlight. you'll see the trigger (black, part of the shutter itself) and you may be able to see where it makes very tenuous, light contact with another part of the mechanism (depending on the model). Carefully clean it with a Q-tip and WD 40 or alcohol. Be careful not to leave any cotton behind. Then apply, with the tube of the Q-tip, some very light grease, and only a tiny bit. Recommended is Super Lube with Teflon available from many industrial supply stores and inter net sites.If the old lube and/or dirt have piled up there, this may be all you need to do.
As for docjibe's problem with no forward/advance, it's a common problem and it means a critical nylon link has broken inside. it usually takes an expert to do the job correctly. In a pinch, you can, with some experience to get the right "touch", gently and quickly brush down and outwards with your thumb, on the grey button marked Select.The tray will usually advance.
Posted on Feb 06, 2008
I replaced the bulb, works fine but now there is no light projection to view slides what do I need to replace?
It definitely has a lens in it then? Kids take them out to play with them and they are pretty useful as a magnifying glass.
If the projection bulb works and there is a lens in it, the only thing it can be is the shutter that comes across the lens to blackout the screen as the slide is changing. As the carousel starts to move, the shutter comes across, the old slide is removed, the new one inserted and then the shutter retracts to show that slide on the screen.
How you get to it and what is likely to be wrong with it, I am not sure, a linkage come off it or something similar?
Jan 24, 2016 | Kodak Carousel 4600 Slide Projector
Minolta x700 cannot see through the lens. help
Which lens? Is this happening with just one lens, or with every lens you mount on the camera?
If you remove the lens and look through it, can you see light? Perhaps an upside-down view of whatever is on the other side?
If you look into the camera body after removing the lens, do you see a mirror at a 45-degree angle?
Aug 28, 2013 | Minolta X-700 35mm SLR Camera
How do you change the parking lights
Signal and Marker Lights
REMOVAL & INSTALLATION
Front Turn Signal and Parking Lights
1991-96 MODELS
  1. Remove the lens upper retaining screw and the fender side retaining screw.
  2. Slide the lens assembly forward until access to the rear is possible.
  3. If necessary, unplug the bulb electrical connection.
  4. Turn the bulb socket assembly counterclockwise and remove it from the lens.
  5. Depress and twist the bulb approximately 1?8 turn
    counterclockwise, then remove it from the socket.
    Fig. 1: Remove the lens upper retaining screw and the fender
    Fig. 2: If necessary, unplug the bulb's electrical connection
    Fig. 3: Turn the bulb socket assembly counterclockwise and remove it from the lens 90986p91.jpg
    Fig. 4: Remove the bulb from the socket
    To install:
  6. Align the bulb's locating pins, then install the bulb in the socket.
  7. Attach the socket to the lens and turn it clockwise to engage it.
  8. If removed, attach the bulb electrical connection.
  9. Place the lens into position, then tighten the fender side and upper
    retaining screws.
Oct 31, 2010 | 1991 Mercury Tracer
How do you install turn signal lens on side mirrors on a 2005 F250?
- Adjust the mirror so the mirror glass is in as far as it will go (meaning if you were looking in the mirror you would see the side of the truck)
- Look inside the mirror housing
- Locate silver clip
- Using a flat screw driver, push the clip in
- Lenses will pop out on the outside
- Remove bulb
- Replace bulb
- Snap back together when new bulb in place.
May 02, 2010 | 2008 Ford F-250 Super Duty
How do i remove indicator bulb on wing mirror Sprinter 2008
It's been a while, you go through the glass.. the big glass.. grab it lightly
slide it up adn then over left.. the bottom glass.. slide it left and the up and right at the same time.. its a little touchy so be patient.. now i cant remember but i think you have to removed the motor.. then you can access the bulb behind it.. best of luck!!
Jan 11, 2010 | 2008 Mercedes-Benz Mercedes Benz Ml Class
Change puddle light , need to know how to take the lens off to change the light bulb in the mirrior of a 2003 ford expedition .
Per the '03 Owners manual...
Approach lamp bulb removal (if equipped)
To change the bulbs:
1. Make sure that all the doors are
closed and the interior lights have
automatically turned off or the
opposite mirror approach lamp has
turned off.
2. With a small flat tipped
screwdriver, insert the tip into the
approach light module slot located
on the outboard corner of the lens
to release the clip.
3. While holding the clip in the release position, pull the approach light
module down.
4. Remove the two wires from the module and replace the module with a
new one.
5. Reverse the order to reassemble the approach light module.
Jul 04, 2009 | 2003 Ford Expedition
Replace taillight bulb - how remove to access it?
wing nuts on innide of trunk hold lens assembly in remove all fastners and slide out assembly to access light sockets on rear of lens.
May 07, 2009 | 1996 Buick LeSabre
How do I change the Drivers side Turn signal bulb in the mirror?
Actually the first answer was right.  On my 2007 Sprinter chassis, the side mirrors have an upper flat mirror and a lower convex mirror.  The upper mirror comes off exactly as described; by tilting it so that it faces down, and then gently lifting it from the top to slide it off the track. (On my sprinter the mirrors are heated, so there are wires that remain attached when you slide it off. This reveals three screws that you can get at with a torex screw driver without needing any flexible shafts etc.  It appears that there is a fourth screw or clip of some sort on the bottom, but I was not able to figure out how to get the bottom convex mirror off to get at it.  That would enable the removal of the full shell. Even without that bottom screw I was able to flex the shell enough to get the turn signal lens assembly out.  But removing it entirely requires reaching in with needle nosed pliers and rotating the bulb assembly a quarter turn, and then reversing the whole assembly to get it back.  In my case I was replacing the turn signal lens, but it should work the same for replacing the bulb. Good luck.
Jan 26, 2009 | 2004 Dodge Sprinter
Replace passenger side power mirror clearance lamp (bulb only).
If you are facing the passenger side mirror adjust the top (large) mirror so that it is turning in towards the truck as far as it will go. Then look behind the mirror in the bottom righthand corner (outside bottom corner) and you will see a silver metal clip. Take a straight head screw driver and push on that clip and the lens will pop out. Then you simply unscrew the bulb holder from the lens and replace your bulb. Good luck!
Oct 16, 2008 | 2008 Ford F-350
Infocus LP70+ has a small shadow in the right lower corner of the display. Could this be a bulb or lens problem or ??? Thanks for any help suggestions.
the light tunnel is collapsing. it's used to hep evenly distribute the light and make the edges crisp. infocus now calls it an integrator rod (315-0055-xx).
to replace the tunnel (rod):
take the top off, take the screws out of the top and the wires out of the circuit board, take the fans out, take off the colorwheel shield, remove the lens assembly (optical engine), remove the colorwheel, take out the 3 set screws, and slide out the tunnel assembly. then remove the foil around the opening and the screw out of the top, and slide the rod carrier out. now remove the metal clip and the pieces of mirror. replace the tunnel (rod), put the clip back on, and reverse the procedure. now, the 2 set screws on the side are to adjust the image, so do not put them in too tightly, and they must be adjusted while the projector is on and the cover is off.
or give it to someone else to do.
Sep 27, 2007 | InFocus LP70+ Multimedia Projector
Kodak Carousel 4400 Slide Projector Logo
231 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
