Question about Nokia N73 Cellular Phone
The following i have problem with phone charging i plug in the cables but the phone does not response
  • 4,102 Answers
Hi how old is the charger often the wires inside the charge fray and short either try somebody elses charger or try you charger on someone elses phone if the charger is working ok then it could either be that the battery needs replacing or that the board is warped on the phone first of all i would try someone elses charger this way you kno the charger is working or not let me know how you get on ok
Posted on Dec 01, 2007
SOURCE:
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
My casio rock wont charge
First Option:
Second Option:
Aug 31, 2012 | Casio G'zOne Rock Cell Phone
Samsung phone shows its charging when its not plugged in.
First Option:
Second Option:
Aug 13, 2012 | Samsung SGH-D980 Cell Phone
Phone will not charge
First Option:
Second Option:
Jul 27, 2012 | Samsung Galaxy S 4G Cell Phone
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
It wont charge atall no matter how long I plug it in
This could be due to one of the following reasons. 1. The charger might be bad. Please charge using cable by connecting to USB port of computer and see if it works. 2. The cable might be bad. 3. The charging port of the phone might be bad.
Mar 10, 2011 | Apple iPhone Smartphone
I HAVE A SOLUTION!
i literally just fixed mine myself.
if your battery is completely dead (like mine was) unplug the battery, put it back in. put the USB cable into the computer, hold "C" on the handset, plug the charge cable into the phone (keep holding "C") the keypad lights should come on, let go and leave to charge. when thats done, download this http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/c510?cc=gb&lc=en and follow the steps to update your phones software. i hope it's not too late, you've probably got a new phone by now.
Jan 06, 2010 | Sony Ericsson C510 - Pay Monthly Cell...
Iphone wont charge or turn on
Have you tried plugging it into a wall socket? That's the first thing to try - if no response still you should leave it plugged in to a wall socket overnight. Sometimes they just need a large prod up the backside!
If it still won't respond try a soft reset (hold home and power buttons together for 15 seconds or so (do this while it's connected to power). If you still have no joy there are a few other courses of action but I suggest you try those first & let me know if you still have no response from it!
Oct 28, 2009 | Apple iPhone Smartphone
Nokia N73 Cellular Phone Logo
145 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
