Question about Magic Chef 9512 Electric Single Oven
Alarm sounds randomly and, "F1" keeps flashing until you press stop?
  • 2 more comments
  • Anonymous May 03, 2008
    every time we leave the oven open when the cooking is finish, it start to ring and write f1 until we close the braker, dose not stop without this.
  • Anonymous Jun 08, 2008
    electric failure and F1 flashing
  • gozh Aug 15, 2008
    With my single magic chef range, the alarm keeps sounding at randon and F1 pops up on the digital - it will go off for a minute when I press stop then it comes back on in a little while again - I've pushed stop, and every button and stop, but it still keeps sounding, even in the middle of something.
  • Anonymous Nov 02, 2008
    The alarm goes off constantly stating F1, I disconnected it at the box to keep my sanity. I think it is the clock that needs replacement. It's an old oven, the part # 100-281D, I got it off the back when I disconnected the clock in order to use the burners. I'm looking for the old part and can't find it, I'm sure it's out there.
Replace the touchpad
Posted on Dec 01, 2007
SOURCE:
Oven keeps beaping and has a alarm symbol showing
Sounds like the timer was set and time is up, the issue is whichever model oven it is has a specific way to stop the alarm. Some just require a simple pressing "cancel" while others use a combination of buttons. I would try pressing either the arrow up or down, if not present just press the "timer" button, see if the alarm symbol changes or disappears
Nov 10, 2016 | Ovens
Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Sep 17, 2008 | Jenn-Air Electric Double Oven
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
F1 and alarm going off .turned power off and and on .kept flashing f1 and alarm noise
normally the f1 code stands for failed matrix in the control brd behind the panel. by removing the panel, after disconnecting power you should find a tech manual which should show the code and solution
May 19, 2009 | Ovens
Range developed problem while cleaning oven
Your electronic oven control is bad and must be replaced.
The clock.
Mar 15, 2009 | Ovens
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
Dacor oven beeping
Keeps flashing F1 and beeping help! how do I make it stop?
Apr 25, 2008 | Ovens
Magic Chef 9512 Electric Single Oven Logo
117 people viewed this question
Top Magic Chef Ovens Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
