Question about Apple iPhone Smartphone
Forgot phone lock code
My cousin died and my aunt gave me his iphone but i dont know the phonelock code.
  • 8 more comments
  • Anonymous Dec 18, 2007
    i found an iphone that was locked and i tried unlocking it by punching in codes but it then disabled i tried hooking it to itunes but did nothing what do i do to reset this??
  • Anonymous Jan 17, 2008
    hi i had same prob my uncle pasted away and his iphone was pasted on to me but when i turn the iphone on it has a phone lock wil this method work the same for my iphone???
  • EyePhone Mar 04, 2008
    I broke up with my girlfriend and before I was able to get most of my valuables back, BUT she got a hold of my IPhone and changed the security code. Since we are not nin good terms, she refuse to tell me what she changed it to. She also said that she forgot........yea right!.
    Can someone please help me fix my IPhone.
  • MUNOZSONS Mar 05, 2008
    I FORGOT MY PASSWORD
  • Anonymous Mar 30, 2008
    sister changed it the day i got it and now it is locked
  • Anonymous Apr 29, 2008
    i bought an iphone from ebay but when i turn it on it asks for a password and i dont know it.. I NEED HELP FAST!!
  • Anonymous May 11, 2008
    i fount this phone but i dont know the unlock code
  • andrewilliam Jan 26, 2009
    it hurts
  • smallz2173 Feb 27, 2009
    found a iphone how to i do the password lock
  • LadyRyza Mar 31, 2009
    Well, i'm using the new Nokia 5800 xpress music and i forgot what's my lock code. Can somebody please help me with my problem. Thanks. :)
    New Friend:
    Problem Solver:
  • 6 Answers
Well i had found this iphone in a rave and i had the same problem that it was locked so wat i did was
1. I connected to itunes
2. I went to the summary tab
3. CLICK restore
As easy as that yeah it does it erase everything but if u found it then it doesn't truely matter
Posted on Jul 11, 2008
Reset the iphone in iTunes
Posted on May 01, 2008
I using N95, and i forgot my 5 digit lock code can someone suggets me how to rest it....thnk you i badly need some help.
Posted on Mar 04, 2008
    Problem Solver:
  • 5 Answers
With help of unlock process u can salve this problem but it is more dificult to do this becarefull
this can be do in total two methodes (os and windows)
with help of os method:it totally take 7steps (be careful to do this)
first step:Download the virginizer package here. the two downloads the iPhone Elite Dev Team hosts on their site, just to eliminate any possible mistakes in finding all the needed files, or in properly merging them
second step: so make sure you are following all of this.
You must have:
an iPhone with 1.0.2 firmware which is currently working.
a fully charged battery.
03.x series modem firmware (mine is 03.14.08_G).
a patched lockdownd file already installed. If you don't and use a non-AT&T SIM your iPhone will leave you at the activate screen which you will need to bypass before continuing.
BSD SubSystem and OpenSSH installed.
Mobile Terminal or Term-vt100 installed (just in case you lose Wi-Fi).
the ability to use Fugu
step 3
Plug in your iPhone to your Mac. Quit/close iTunes. Don't just minimize it, shut it down. If you have the iTunes Helper open, you must quit that as well. To determine if they are running, open the Activity Monitor program found in the Utilities folder inside of the Applications folder. If it is running, highlight it in the list and click the "Quit Process" button.
step 4
If you are using any program (like Services) that gives you the ability to turn off your SSH server on your iPhone, then make sure your SSH server is turned on right now.
Also, make sure to press your Home button, then press "Settings", "General", "Auto-Lock" and "Never". It would be disastrous if the iPhone went into sleep mode during this process.
step 5
1)Launch Fugu. Copy the "virginizer_pack" folder (which you downloaded in Step 1), to the /usr/bin directory on the iPhone
2)Go into the virginzer_pack folder on the iPhone. Make sure the following files all have executable permissions (preferably 0755) set so they will run:
bbupdater, eliteloader.bin, iUnlock, norz, virginator.sh
If you don't know how to change the permissions, simply right click the file
3)Enter 0755 into the field next to "Octal Mode Representation:". Then click the "Apply" button. Do this for every file
4)Your folder should look like this when you are done.
5)Launch the Terminal. I did this on my Mac since I needed to take screen shots, but you could do this directly from your iPhone.
step 6
Type: ssh -l root (your iPhone's IP address) PRESS RETURN
Type: (your password at the prompt) PRESS RETURN
Type: cd /usr/bin/virginizer_pack PRESS RETURN
./virginator.sh PRESS RETURN
Now just follow the prompts. 1....2.........yes
****Note: at ths point a seczone.backup file has been created. If you click "Reload" in Fugu you can be extra paranoid if you want and back that file up right now. Close Fugu when you are done. *******
A lot of code will scroll by as the flashing process continues. Eventually it will end with a prompt symbol
If you haven't already quit Fugu, you should now. I noticed that even after closing it the following command didn't work for a couple minutes. So if it fails the first time, try it again later.
Type: ./bbupdater -v PRESS RETURN
You should have the same output I have here
You can close the Terminal and restart the iPhone.
Note: Your iPhone is now running 1.0.2 firmware with repaired 03.14.08_G modem firmware. Continue below to update your iPhone to 1.1.1 firmware and 04.01.13_G modem firmware. Your iPhone will be locked after continuing.
step 7
1)Launch iTunes and click "Install".
2) updated A LOT of iPhones in my time and this one took a very long time to update. So don't panic.
3)
When the iPhone starts it'll be at the activate screen. iTunes will display the Welcome to Your New iPhone screen
While I'm not going to go into depth on this, you could use the emergency keypad exploit (dial *#307# then 0 then make a contact with a home page URL of prefs://1F) to go into the settings screen to verify that you are on 1.1.1 with a modem version of 04.01.13_G. But you really don't need to.
I recommend now following my Step 1 tutorial to proceed with the jailbreaking and unlocking of the iPhone.
before u do this be carefull my friend..................
Posted on Dec 03, 2007
Im using N95 and accidentally i forgot my lock code can someone help me reset or any other way i could find my combination number again. badly need yur help guys.....
SOURCE:
I have iphone model A1241 and im trying to jailbreak that one but as i do the i need to type the passcode but i dont know the passcode that iphone is given to by my cousin
Then call him up and get the code. If it's a screen lock. There's no way to get around that. And most of us tech's think automatically "stolen phone" if someone "loses" their code when most people use their phone multiple times a day.
Aug 31, 2011 | Apple iPhone Smartphone
I tried to restore my iphone cos i forgot the phonelock code,but after i did the restore,my phone is still lock and its shows the usb and itunes icon instead. what do i do?
Did you restore it from the backup? If so, you must restore again and setup as new. If not, then what you are seeing is the connect to iTunes screen. Unplugged the iPhone and plug it in again.
Feb 26, 2011 | Apple iPhone Smartphone
I got a phone from my cousin but he forgot to give me the passwor
The passwords are to protect misuse of the device by unauthorised persons, you included. Hence, there is no way that you can use it without reinstalling the firmware whether you do it yourself or AT&T does it. Would it not be cheaper to locate your cousin and ask him the password.
Dec 11, 2009 | Samsung Behold Cell Phone
Forgot my phonelock code
hi
please call your phone service provider to obtain the unlock code.
May 10, 2009 | Cell Phones
How can i unlock the phonelock'
call your provider and tell them that you want to unlock it, or go to a phone shop in the city centre and he should be able to do the trick for u
May 06, 2009 | Sony Ericsson K600i Cellular Phone
Unlocking LG VX4400
I heard *228 might work..but it might be an activation code..not a reset code. I'm going to try it.
May 27, 2008 | LG VX4400
try the 2222 default code
Apr 12, 2008 | Computers & Internet
How to cancel my phonelock code because i forgot it..
if you can not remember the code , take it to a mobile service center and have them reset it back to it's default settings.
Nov 11, 2007 | Sony Ericsson K750i Cellular Phone
Apple iPhone Smartphone Logo
2,458 people viewed this question
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
