Question about HP DeskJet 990cxi InkJet Printer
No Yellow Or Cyan Ink
The last two color cartridges I've installed only print magenta. Both cartridges are new HP 78s. I've tried all the troubleshooting options in the HP Toolbox, but nothing helps.
Even though this is an older printer, it's been used very little and should NOT be DOA.
What can I do to get this printer working?
Thanks for your time and assistance.
  • 2 more comments
  • 12jim Dec 29, 2007
    I have had exactly the same problem, but only with yellow. I have cleaned everything several times but still no yellow.
  • J Barnes Jan 29, 2008
    Unfortunately, I tried all those steps when I first started having trouble with the printer and had no change at all.
    So, I guess it's the scrap heap for this machine. I'll never own another HP as long as I live, world without end, amen.
    I do appreciate your taking time to answer.
  • Ian Marsh
    Ian Marsh Mar 08, 2008
    Have had same problems - have got cheap recycled cartridges - three unused - one will not print any colour, one will do only magenta, one will do only yellow. Am reluctant to buy a genuine HP item in case the printer is the problem. Have wasted a lot of time in going through clean/prime cycles - has made no difference.
  • Anonymous Feb 06, 2009
    Mine would only print one of the three colors. The #78 cartridge was old (but never used) and I replaced it with a new one and it worked.
  • 417 Answers
Hi do the following and hopefully it will help you. If it doesn't then you have a fault carriage or main PCB.
  • Remove ink Cartridge
  • With a soft cloth wipe clean the gold contacts on the carriage unit and the same on the ink cartridge
  • reinstall the ink cartridge
  • Click start
  • Select printers and faxes
  • Right hand click on the printer icon
  • Select Properties
  • Click on Services Tab
  • Click on clean print heads
  • Then click on Prime.
Hopefully this will work
Thanks J
Posted on Jan 14, 2008
Tried all these - still no yellow!. Will buy one new cartidge and try for the last time
Posted on Jan 29, 2008
I have also tried all the steps you suggested (lots of times). No yellow ink, though. Have decided to get one more new cartidge and try again for the last time.
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Prints only green predominently
Without knowing what printer you have or what things you have tried I can only guess here. It sounds like you need a new cartridge. A color ink cartridge will have 3 colors of ink for most printers...cyan (blue), magenta (purplish-maroon), and yellow. Depending on what you print it is very possible that you could run out of one of the inks before the others. Printing green can be an indication that you are out of magenta ink. The cyan and yellow inks will combine and look green.
You can remove the cartridge and run a tissue over the printhead and see if you see all 3 colors as a quick test. If you only see cyan and yellow, then the magenta is probably empty or dried up. If you see all 3 colors I would reinsert the cartridge and try printing again. It is possible that the magenta was just clogged and you cleaned it with the tissue. If it still doesn't print all colors your best bet is probably to just get a new ink cartridge.
Sep 10, 2008 | Office Equipment & Supplies
My G85 wont print yellow
This can happen for very old cartridges, even if they still have ink. The cartridges have a shelf life and can lose colors (usual yellow and cyan first) if stored for years.
If this is an original HP cartridge check the cartridge warranty date as shown here. If the cartridges are within their two year warranty call HP at 1-800-HPINVENt or contact your dealer for replacements. If the cartridges are beyond their warranty period then purchase a fresh cartridge.
When buying new cartridges look for the "install by" date on the package. I would look for a package with at least six months remaining before the "install by" date, which would have a year of remaining warranty.
When storing unused cartridges for an extended period keep them in a cool place and keep them upright as they would hang on a store display. This will provide maximum shelf life.
You can verify the issue is the cartridge by carefully blotting the printhead on a damp tissue. A good cartridge would have a stripe of Cyan, Magenta and Yellow, your cartridge will only show Cyan and Magenta.
I am sure that a fresh cartridge will solve your problem.
Bob Headrick, MS MVP Printing/Imaging
May 09, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP DeskJet 990cxi InkJet Printer Logo
163 people viewed this question
Ben Johnson
