Question about Saeco Vienna De Luxe Espresso Machine
Significant leak into drip tray when brewing and using steam/hot water
Had my Saeco Vienna Dlx for 3-4 years, recently water started filling drip tray when brewing and turning steam/hot water knob on. Steam & hot water no longer dispense, just sounds like it's trying. Seems like maybe water line is clogged, but no clue. Called a repair center, said it sounded like the boiler. I have never done descaling, but I use only filtered water. (However, lots of minerals in our water) Before I take it in, I want to see if anyone else has had this problem. Thanks!
  • 1 more comment
  • latte junkie Dec 10, 2007
    I ran the vinegar & water solution through the machine and has some success. The brewing cycle doesn't seem to be causing excess water to run out anymore. The steam/hot water dispenser still does not operate properly and continues to create a flow of water into the drip tray. I will try descaler next. Thanks for your help!
  • latte junkie Jan 09, 2008
    great information, the descaler didn't work, so i took it to a service tech.
  • Anonymous Mar 23, 2014
    Steam works hot water does not
    Problem Solver:
  • 8 Answers
If the blockage was in your boiler there wouldn't be water in your drip tray. However, it wouldn't hurt to descale after this many years. Vinegar is NOT a good idea as the scale will only flake off and may block other components including the solenoid. A good descaler will disolve the scale so it easily flushes and stores that sell coffee machines usually sell the descalers as well.
There are several regular checks you should do on your machine.
1. Remove and clean the brewing unit at least monthly paying extra attention to the filter that plunges onto the ground coffee and that the coffee passes through before passing into the dispenser. Dried coffee oils will block this filter if left unwashed and water will back flow into the drip tray and dregs drawer.
2. Check that there isn't any ground coffee in the cavity behind the brewing unit (below the nipple) and that the hole at the base of this cavity is clear.
3. Replace the brewing unit. While the door is still open you will be able to operate the machine if you trigger the lever that the door normally triggers. On your model there is a trigger at the top of the door frame. Run water/steam and check to see if there is water dripping from around the top joint of the steam arm when you do this. If no steam at all comes through the steam pipe, but it comes out around the pipe, then you should get it checked by a technician as the tap assembly may be fractured and need replacing.
Posted on Dec 09, 2007
  • 24 Answers
Run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Posted on Dec 06, 2007
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
I own a saeco Vienna 'limited edition'. When making coffee, the cycle stops when the water pump starts. Coffee light blinks and the red light turns on. It started when i tried to use the steam...
Hi. Sounds like a blocked or jammed brew unit. Remove brew unit and clean. To properly do this, you need to disassemble the brew unit. Canbe quite hard to do. The brew units are usually held together with plastic tabs, and may have to remove some screws to allow these tabs to release units assembly. Dazza REPAIRER
Sep 24, 2011 | Saeco Vienna SuperAutomatica Coffee...
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Coffee and steam lights flash after using steamer and will not go solid
Hi
Once you have finished steaming, turn the steam button off, then open the knob and let the steam out. The water pump will turn on again and bring the temp back down. When the pump changes tone, the light will go off and you can brew again. It takes less than 10 seconds.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Incanto deluxe started dripping hot water from the steam spout outlet when coffee is brewing. It produces steam and hot water without any problems. It doesn't leak when it's in a normal state...
Either the grind is too fine and there is so much pressure that the pins in the steam valve are not working properly. First try to adjust grind a little coarser, it that does not work, then the pins in the steam valve need to be replaced.
Nov 20, 2009 | Saeco INCANTO DELUXE Espresso Machine
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
554 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
