Question about Kicker ZR600 Car Audio Amplifier
Load?? the power amplifers get hot tip36c/35c and begin to drag down the power supply, first i thougt it was a interment problem but now im not sure its ok the first 30sec to 1 min then the ps starts making noise and i can watch the voltage drop on both the + and - sides, biasing problems??
  • 631 Answers
It sounds like it could be biasing. Measure the DC voltage across the emitter resistors. If it's more than 0.001volts (1mV), reduce it to 1mV. The output transistors MUST be clamped to the sink when setting the bias current. Recheck the biasing after ~5 minutes of idling. The bias transistors (Q7, Q27) need to be in contact with the heatsink.
These amplifiers also have a problem with the shield ground fuse opening. This can lead to oscillation which can mimic biasing problems. You would need to use an oscilloscope to see the oscillation. You can check the shield ground. Disconnect the RCAs from the amp and measure the resistance from the shield of the RCA jacks to the center tap on the secondary side of the transformer. It should be ~0 ohms.
Posted on Dec 01, 2007
Dometic AC B59516.711 15,000 BTU, while on generator power the AC works during day while it hot but once the sunsets and it cools down, compressor kicks on it drags the gen down and shuts it off.
something else besides the ac is stopping ( overloading) the genset
if it works well during the day, the compressor has to be working so the ac is not the problem
a 4000 watt gen set has a duty cycle load of around 3000 watts full time so any additional power requirement besides the ac will overload it
electric stoves , microwave ovens , hot water elements , anything that consumes power after dark will when combined with the ac will overload and shut down the gen-set
Jun 26, 2017 | Electrical Supplies
My top load water dispenser stopped dispensing on the hot tub side, what do I do?
I'd follow the hot water supply hose to the back of the washer and and then - after unplugging it from the power - begin check to make sure hot water is available to the hose by disconnecting it and aiming it into the washer - and turning the water on. If it flows, check for debris clogging the strainer screen at the input to the washer. Then if ok - check the hot water valve solenoid with an ohmmeter. Compare it to the value of the cold water solenoid valve and if not within 10 - 15% - replace it. If you can check for 120 volts to the hot water solenoid SAFELY - do so - otherwise, stop and call a pro.
Dec 02, 2014 | Washing Machines
Boiler reset
what does this have to do with vehicle care and maintenance? regardless, find the manufactuers website and im sure you can track down the pdf file that answers your question for that model
I’m happy to assist further over the phone at https://www.6ya.com/expert/josh_8f8ad0a8f7e0e6d3
Feb 13, 2014 | Manual Units Sphygmomanometer Pressure...
I have a VOX NT15. When switched to Triode ( 7,5 W ) mode, my amp generates quite loud buzzing sound. The loudness of this sound is on the same level, no matter if the volume is switched to minimum or...
You LIKELY have a bad filter capacitor. The additional load of the Triode load is probably dragging the supply causing flattopping and the power supply ripple frequency to come through. Have the unit serviced.
Jul 26, 2011 | VOX Amplification Vox Night Train Amp Head
Hitachi Plasma HDTV turns off by itself. indicating lamp flashes.
The unit senses a fault in the power circuit. It is either in the power supply unit (PSU) peripherals or in the PSU itself.
  • One of the peripherals might be loading down the PSU causing it to shutdown.
  1. Check the power input terminals of the peripherals for any short circuit using an ohmmeter.
  2. Replace any part found to be causing the issue.
  • The power supply unit cannot run under load and shuts down. It is usually caused by bad capacitors.
  1. Check the PSU board for any bad capacitor.
  2. Replace bad capacitors with the same specifications.
  3. Make sure to replace the capacitors in correct polarity.
  4. Bad capacitors look like these:3a72a3c.jpg17dffa0.jpg
Nov 03, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Have a Maxon CB Model MCB30 that has a resistor that is red hot resistor part number R999 Any idea as to why this is happing and what the value of the resistor is as the color code has burned off and it is...
Hello, This means that the unit is drawing excessive current which is usually an indication of a short circuit within the unit. Now since the resistor is glowing red hot this narrows down the possible causes. I would suspect the RF amplifier stage as the possible cause, more to the point the RF amplification IC or FET is the item that has shorted out. I would also advise checking the audio signal amplifier to. You will need a schematic diagram of the CB, a Multimeter, an antenna dummy load, and a 12V power supply. If you have a background in electronics this task should be doable, if not I would suggest that you take the unit to a qualified technician for servicing. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Mar 17, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Un usual rpm spikes
At a guess.... Your clutch is slipping. Higher gears and increased drag at hiway speeds put the most torque through the clutch and it sounds like that's when the plates start to slip. When you back off the plates grab again until the load over powers the plates again. But that's just a inter-guess through a computer screen...... ,,
Nov 10, 2008 | 2008 HM CRE F450XI
Fuel consuption very high
drive a miles on an open road, dont use your brakes. Coast to a stop and feel your rims, they should be cool or air warm, not HOT, that means dragging brakes, check rears too for E-brake drag.
Jul 12, 2008 | Kia Sedona Cars & Trucks
Kicker ZR600 Car Audio Amplifier Logo
90 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
