Miller & Kreisel Subwoofer 60Hz hum
When I plug in my subwoofer, I am getting a 60Hz hum, even when it isn't connected to the stereo. I've tried plugging the woofer into a Monster Cable filtered outlet (designed specifically for subwoofers), but I am still getting the same hum. I fear that the sound board may have a burnt out circuit. If this is the case, is there any place that I may send the sound board to have it repaired, now that the Miller & Kreisel company is no more?
  • 2 more comments
  • camaro11 Jan 04, 2008
    I have a v-125 sub with the same symptoms and was wondering the same thing as you but so far no luck. I think I need a new speaker as I can hear a rattling in it when the bass volume is turned up. There are several shops that repair speakers so my next step is to contact one of them if you hear of anything let me know.
  • rrussell Feb 10, 2008
    The problem started with very low volume. I would turn the source knob up and down rapidly and it would kick in and be fine for a while until the next time I used it. Then many times the same thing would happen. Finally it went out completely. I believe the problem is in one of the circuit boards. does anyone know if you can buy the circuit boards in the Mk2's?
  • shurst3 Jun 29, 2008
    MX-125 subwoofer hums very loud when a signal goes to it. Tried different receivers with different cables. Once a signal gets to the subwoofer it appears to fire over and just hum very loud. Unplug cable and it does not go away. It will only go away when unplugged.
  • ercble Mar 15, 2009
    I have a Miller & kreisel MX-105 subwoofer and when I plug it in and turn up the volume instantly I get a solid bass hum. ercble
    New Friend:
My MX 200 recently started humming even with no input signal line connected. Smitty8000 was correct and all I had to do was exercise the volume knob to make the problem go away. It seems when it sets for years with out being changed the wiper loses contact. A good vigorous repeated moving of the knob fixed the problem -- at first it made did some thumping while turning the know but this went away as did the hum.
Posted on Dec 27, 2009
This is a common problem.  The potentiometer is damaged and needs to be replaced.  Potentiometer is a fancy name for volume knob.  It's a $5.00 fix if you know what you're doing.
Posted on Feb 25, 2009
Try using a ground lift on the sub. Good luck.
Posted on Mar 06, 2009
SOURCE:
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Why does my HTS-20 powered subwoofer make a low hum when plugged in, even turned off and not connected to the receiver and a louder hum when the subwoofer power is turned on?
I suspect the amplifier is damaged. This is not an easy repair to do unless you are well versed in audio electronics. I would recommend a repair shop to look at the subwoofer amplifier.
Jun 03, 2015 | Infinity HTS-20 System
Subs hum when i turn of my stereo
When it only hums when you turn On the stereo, check the cable and connections .
When it hums, even without anything connected to it, then it needs repair
Sep 24, 2012 | JBL PB12 Subwoofer
Esw-c10 subwoofer hums and dont work
if you short a sub it will hum try connecting it to a working speaker (no amplifier) if you have access to rear of sub check for wire only needs to be the size of a hair arcing out the speaker, i have a sub that does that on only one output (left rear) its actually the stereo causing it to hum..
Jun 20, 2012 | Energy ESWC10 Subwoofer Speaker
Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 03, 2011 | Velodyne VX-10 Subwoofer
After a power outage I have a loud hum.
Hi, The Ground Rules Of all the annoyances that can afflict any audio/video home theater or even a simple stereo installation, the notorious "ground loop" may well be the most difficult and persistent one to track down and eliminate. A "ground loop" is caused by the difference in electrical potential at different grounding points in an audio/video system. (All the grounds in an A/V system should ideally be at "0" potential.) A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio or video components, including subwoofers, cable-TV outboard boxes, satellite-TV feeds, TV displays, amplifiers, A/V receivers or turntables. The buzz/hum is a byproduct of the multiple power supply cables and a ground voltage differential within your system and its network of interconnecting cables.
Here are some methods to help you get rid of ground loops. Try these first and don't waste money on a power "conditioner" which, in most cases, won't help. (There is no need to "condition" the AC power for your system. Your receiver or amplifier already has a power supply with its own filters and transformers. No further filtering is normally required.)
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your cable-TV or satellite-box feed at the entry point to your system.
First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed.
Reconnect your subwoofer's coaxial cable from the subwoofer input to your receiver's subwoofer output and disconnect the cable-TV feed (or satellite feed) from your outboard set-top cable box or satellite tuner. Be sure and disconnect the cable before any splitters. Now see if the hum/buzz from your subwoofer stops.
If that eliminates the hum, you can install one of these inexpensive in-line ground isolators from Parts Express or Bass Home. Note that these transformer-based ground isolators will work fine with analog cable-TV feeds, but depending on their design they may interfere with or block reception of HDTV signals via a digital cable or satellite dish feed.
Install the ground isolator between the cable-TV feed and the input of your outboard cable-TV box or satellite tuner (or the TV display's antenna or cable input if you have a set with a built-in TV tuner or a cable-card ready set). In many cases, the ground isolator will "break" the loop and remove the annoying hum or buzz by isolating the TV-cable ground.
If a hum remains with the TV cable completely disconnected from your system, or you don't want to risk degrading reception of HD signals from a cable or satellite system, then you may have to add a ground isolator like this Radio Shack Model 270-054 between the line-level coaxial subwoofer cable from your A/V receiver and the line-level input jack on your powered subwoofer.
In all cases, if your subwoofer has a ground-lift screw like some of Axiom's subwoofers, try first removing the screw (or replacing it) to see if it increases or eliminates the hum. It may or may not make a difference.
If you do not have easy access to the aforementioned ground isolators, here are a few more tips:
Try plugging the subwoofer into a different AC outlet in the room, one that isn't supplying power to your components (A/V receiver, TV, cable box, etc.). That might fix it.
Try reversing the AC plug for your A/V receiver or the powered subwoofer. If it's a 3-wire plug or a polarized plug, which has one prong wider than the other, you won't be able to reverse the plug. For safety, do not use a "cheater plug" to bypass the 3-wire plug.
With the power OFF, reverse the AC plugs one by one of any other components that have a standard 2-prong AC plug that isn't polarized. Each time you reverse a plug, turn on the system with the attached component and your subwoofer and see if the hum disappears. In some cases, reversing one or more plugs will eliminate the hum.
If you have a turntable, try connecting a separate ground wire to a chassis screw on your preamp or receiver and see if the hum disappears. If you already have a turntable ground wire, try removing it from the preamp. One or the other may eliminate the hum.
Finally, here is another solution that worked well for a member of our message boards who decided to discard his ground-loop isolator on his subwoofer: "I took off the ground-loop isolator I'd been using and connected a plain 14-gauge wire to chassis screws on the sub and the receiver then powered everything on. Although hum was still there, it was far lower than before. Next I unscrewed the ground-loop screw on the back of the sub and that took care of the hum completely."
Almost certainly sounds like an earth loop to me, but can be caused by a poorly made transformer or phase shifts on the mains supply. Visit some power conditioner web-sites like Isotek or Isol-8 (or google "earth loop") where there's plenty of advice on how to reduce/eliminate earth loops and other causes of mains-induced hum (transformer problems etc).
Hum on the speakers usually indicates that there is a DC voltage on the speaker line. DC voltage on the output lines would be caused by a shorted output transistor.
Have a nice day...
Feb 16, 2011 | Cambridge Soundworks BassCube 12 Speaker
Sunfire MK II Subwoofer hum. I have a Sunfire MK II subwoofer that hums when it is plugged in (it even hums when no signal is connected). I've tried multiple outlets on different circuits, but hum...
you have a ground loop issue you could purchase a ground loop isolator, jensen makes them for about 40 bucks.I have discovered that if you have cable tv, unplug the incoming cable in your cable box and see if hum disappears.
Nov 25, 2010 | Sunfire True Sub MK II Subwoofer
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged...
jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Jan 30, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
When i plug in my subwoofer it has a constant hum
Sounds like you have a bad connection somewhere. Make sure all of your connections are secure. If theres anything that is a little loose you'll get that hum. You might also try replacing your cable too. If it became pinched somewhere it could cause that problem
-Captain Jake
Feb 11, 2009 | JBL PB10 Subwoofer
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
1,531 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
