Question about Electrolux Guardian Bagged Canister Vacuum
Power cord will not retract
I have an Electrolux Renaissance, which I take very good care of and is going strong. The power cord retractor stopped working when the cord was fully extended and will not rewind. Any suggestions?
  • 1 more comment
  • Pondside Dec 03, 2007
    I disassembled the Lux 5000 vaccum cleaner and some of the wires disconnected from its terminals.Now I have a problem on replacing the wires.Please advise, where I can find a wiring diagram.
  • Anonymous Dec 08, 2007
    Same problem. Cord is extended to the limit and won't move to engage retract mechanism. How do you disassemble the machine to get to thr retraction mechanism?
  • Anonymous Mar 28, 2014
    Removal of cord rewind
  • 75 Answers
Your cordwinder is broken take it to your local Aerus Electrolux dealer. If you have any additional problems call Liz at 570-326-1731
Posted on Dec 27, 2007
SOURCE:
Simplicity mode l8526L pull cord wont retract
The retractor has failed. You will have to disassemble the machine, find the retractor and repair/replace it.
Jul 12, 2016 | Simplicity Vacuums
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
Cord retractor doesn't work
does it retract at all or not at all? or does it not stop when the cord is pulled out any amount?
Oct 20, 2011 | Electrolux Guardian Bagged Canister Vacuum
I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
May 24, 2011 | Electrolux Guardian Bagged Canister Vacuum
The power cord is fully extended and will not retract in Miele LUNA vacuum cleaner model s4580
Keep playing with it, it will go if you are careful. The alternative is to disassemble the device and get involved with the retractor system. This is not always a simple task with springs under tansion, reassembly required about 8 hands ... which MAY be a small exageration.
Thanks for your question @ FixYa.com
Mar 23, 2011 | Vacuums
Cord will not retract?
This is caused by a broken retractor reel spring, you will need to replace the retractor.
Jan 28, 2011 | Electrolux Epic 6500 Vacuum
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
It sounds like the rewinder spring either came off the retainer or broke. If it broke it must be replaced. If it just came off, it can be put back on and rewound. It is a LONG flat piece if springsteel which is VERY sharp. Be Careful.
Dec 17, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electolux renaissance
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576614
Generic problem for all Vacuums
Electrolux renaissance
Posted by maryannn2l on May 06, 2008
No power when I plug into outlet
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have 3 problems that I can see. You may have a bad electrical outlet, but I doubt it, the bad cordwinder cord or a short in the cordwinder itself, or a connection came loose in the motor section. If you need further assistance then contact your local vacuum cleaner dealer in your area or contact the Electrolux factory listed below. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
654 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
