Question about Dell Inspiron 5160 Notebook
Problem Dell Inpiron 5160
I have a problem in my Dell Inspiron 5160.
I plug the charger on my laptop and when I press the power button the orange light is blinking triple.
Please help me, I replacing motherbord.
  • Maciekpl Dec 02, 2007
    Hi Romeet
    I have a new motherboard and i replaced the orginal motherboard with the new motherboard and the orange light begins to blinks after inserting the new motherboard.
    I have an electronic background and I am Qualified in electronics.
    Thank You
    Maciekpl
    Dear Romeet
    Thank you for your quick reply.Your suggetion of removing the battery and running the laptop from the AC adapter directly solved the problem.
    THANK YOU
    Maciekpl
  • 66 Answers
Hello Maciekpl,
This is Romeet,i would like to try and help you solve this, please let me know if you have a replacement motherboard for your laptop ready? also let me know how comfortable would you be with opening up the thing and replacing it?
B.Regds
Romeet
Posted on Dec 01, 2007
  • Romeet Barmeda
    Romeet Barmeda Dec 02, 2007
    Hello Maciekpl,
    Hmm that makes it easier with your experience.I strongly suspect the battery or the Battery charging section,also i am assuming you have taken the exact model and sub series motherboard replacement confirmed to be working well.
    try removing the battery and then trying to run the laptop from the AC Adapter directly?if that doesnt work,return the battery back into the laptop and keep it for cold charging for about 4 hours ( without turning ON the laptop - as you would a mobile phone whose battery is completely drained off ). Try after that?
    B.Regds
    Romeet
  • Romeet Barmeda
    Kool Maciekpl,way to go! all the best :)
SOURCE:
Mydell 5160 has a yellow blinking light on the front 1st from right. any suggestion on cause or solutions.
It is the battery Status indicator and flasing orange light indicates that battery is low. After connecting the charger it should turn solid green, which indicates that the battery is charging and it turns off when battery is charged completely.
If it continously blinks, check out the charger and battery.
Dell 5610 owner's manual can be downloaded from:
http://support.dell.com/support/edocs/systems/ins5160/en/OM/G74822LRs.pdf
Check out Page-15
Let me know if any clarification is required
CreativeTECH
Nov 12, 2010 | Dell Inspiron 5160 Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell 5160 Won't start up or charge battery
I have the dell inspiron 5160 works great a little slow but no big deal. The problem I have as of Monday the power cord will not stay in and now will not charge. Is it the power port? Can this be fixed?
Jun 27, 2009 | Dell Inspiron 5160 Notebook
Dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
Feb 17, 2009 | Dell Inspiron 5160 Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Black screen on power up
There is a small board that the power button is integrated into that connects to the motherboard. When this power board malfunctions it will cause this issue with the machine. It can, and quite often does, damage the motherboard when it malfinctions. You should take the machine in for a power board replacement and a diagnostic to make sure that the power board hasn't damaged the motherboard.
Jul 14, 2008 | Dell Inspiron 5160 Notebook
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell 5160 orange light
removed battery, and acadapter FROM UNIT, HOLD DOWN THE POWER BUTTON 60 SECOND That should drain the power from it
Mar 26, 2008 | Dell Inspiron 5160 Notebook
I have a big problem in my dell inspiron 5160!
Please let me know the battery condition...
Jun 15, 2007 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Notebook Logo
634 people viewed this question
Ekse
Clive
Clive
