Panasonic PT-47WX49 47 in. Rear Projection Television
Problem for Panasonic PT-47WX49 47 in. Rear Projection Television
How to fix a Panasonic PT53WX42F distorted image?
By hawklt1 on Aug 17, 2009
I have a Panasonic PT53WX42F and it has a distorted image. I tried using the owners manual to fix the convergance and that might have helped a bit but the top and bottom of the picture pull towards the center of the screen. Can this be fixed? Can I do it myself?
Best Solution
posted on Aug 31, 2009
Very Helpful)
Ecollier2012
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 93%, 642 votes
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 17, 2009
Very Helpful)
asnowman
Rating: 95%, 671 votes
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
What happens in the Panasonic set is that the convergence IC’s will short and cause the power supply to shut down from the overload of current, this can happen if the repair is not made soon enough. Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so. You will also want to replace the white heat sink compound that is on the heat sink, just scrape it off, then clean the surface with alcohol. Then apply a thin coating of fresh heat sink compound, if you do not do this important step the new IC's will not last long as the old compound will act as an insulator to the heat transfer.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Was this helpful?
Yes
No
4 people thought this was helpful
Asker's Testimonial
" Very precise and detailed information. Extrememly helpful and knowledgable. I can't thank you enough. " - hawklt1
Popular Solutions for Panasonic PT-47WX49 47 in.
Questions and Unsolved Problems for Panasonic PT-47WX49 47 in.
Do you recommend Panasonic PT-47WX49 47 in. Rear Projection Television?
Answer
Answer
we have a 1991 46" rear projection tv. The thing looks like it was just delivered. the picture... (More)
Answer
I have a Panasonic Rear projecction (PT-47W42) with a double vision, the right side of the screen is... (More)
Answer
I'm looking for a replacement mirror for Phillips model 9P5511C102, is this an easy replacement and... (More)
Answer
need a service manual for panasonic pt47wx49. jonna1966@hotmail.com
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(704) 315-5981
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
