Question about Black & Decker (050876530606)
Black & Decker Coffee Maker DE755B--Thermal Fuse
The fuse that controls the heating element is blown. It has several numbers
36TMHO1
56C223
L150-15c
S0630
Do you know where I can purchase the fuse. I tried Radio Shack
Thanks
John
  • 2 more comments
  • Craig Czar Dec 03, 2007
    I've got two that are bad, same problem. I think it is caused by pouring water in when the unit is on and the heater is hot. I need two and they are spot soldered on (hi temp).
  • jgreeks Jan 06, 2008
    Black & Decker 12 Cup Coffee Maker DE755B
    Question
    The thermostat is blown. The numbers on it are
    36TMHO1 560223 L150-15C SO635
    Do you know where can I purchase this part (locally in Dallas if
    possible).
    I troubleshooted the problem down to this thermal switch, and, after
    shorting across it for a few seconds, caused the unit to warm up and work
    again.
    I'm willing to pay a few bucks for it, but a whole new coffee maker costs less than some quotes I've been getting.
    Thank you,
    Jerry
  • John61 Jan 27, 2008
    Thanks everyone, I even tried Emerson Electric and they had a thermostat but would not sell only "one"---fifty -"Yes". Eventually I bought a new Proctor Sylex sp? for $12.00 at Sears
  • mailboxtom Mar 16, 2009
    I have the same black and decker coffee maker and it quit working one month after buying it. No heat=no brewing. It seems right in line with all other black and decker products I've had experience with... it doesn't last very long. Black and Decker should change their name to Junk and Decker.
    Problem Solver:
  • 8 Answers
Hi, the actual part you are talking about is not the heat fuse but the heat relay.
I have the same coffee pot, it 'died' on me and I was able to fix it. I actually had a bad relay AND a bad fuse. Here is what I did to get it working again WITHOUT purchasing any new parts and still keeping things SAFE.
Fist, unplug it! Remove the bottom cover ( you may need a special screwdriver for one of the screws, I had to file a notch in an old flat head ).
Unscrew the nut that connects the element to a bracket and to the plate. Remove the parts and set aside.
First thing you need to check is to see if it one ( or both ) of the actual fuses are burnt out. There is a wire that goes from the relay ( white ceramic cylinder ) to the heating element ( thick aluminum loop ), this wire has an extra sheath on it. Under this sheath there are 2 heat fuses in series. Check these fuses to see if one or both are burnt out. One of mine was. If both of yours are burnt out, you will need to order new ones ( see a post here ), if only one is out, you can do what I did. Using 2 pairs of needle nose pliers, I carefully loosened the crimping on both sides of the burnt out fuse and removed it. Using the same crimping I attached the remaining good fuse to the wire. Make sure you now have continuity from the output of the relay to the element.
The relay is the round ceramic thing with an aluminum "cap". It is attached to the heating element via a small black clip. Put an ohm meeter across this piece, if you have continuity, the contacts are probably welded shut, which is why your fuse blew. If not, the likely cause it, the contacts are burnt. Either way the fix is the same.
At the base of this relay there is a small lip. I used a small file to make this lip thin in one spot, then I carefully peeled it off all the way around. There is a crease right before the lip ( the part of the cap closest to the wires side of the relay ) and the lip peeled away nicely along this crease without damaging the cap itself. You can now remove the cap part and see the relay workings underneath. Be very careful when you remove the cap. Under the cap is a black piece of some kind of rubber with a tiny white piece of plastic in the middle. Don't lose these.
Now using an old toothbrush and some acetone clean the relay contacts and carefully free them if they are welded shut. Now use a small piece of fine sandpaper to clean up both of the contacts. Check the unit with a ohm meter, and if you have continuity, this part is done.
Now that you have peeled the lip off the relay, the pressure of the clip is required to hold it together. Carefully reassemble the relay ( don't forget the little white piece ) and while holding it together, against the spot on the element you removed it from, slide the clip on and back into place. Using the ohm meter again, check that every thing is connected as it should. With the switch on ( you DID unplug it, RIGHT? ) you should have continuity all the way from the plug to the heating element. If all is well put it back together and make some coffee.
I had some extra thermal grease laying around, so I cleaned of the old stuff and put some new on before reassembling ( where the element contacts the burner plate ). This probably not necessary, but not a bad idea either.
Posted on Aug 13, 2009
  • broomfieldto Aug 29, 2011
    Perfect repair thank you
Besneatte: Bravo....nice analysis and repair.
Using a voltmeter, I traced out where the 120 volt supply was broken in the heating coil circuit.
It was right at the sensor (it is there to break the circuit if the coil gets to hot and then turn the current back on when it cools).
Unfortunately, I destroyed the aluminum cap taking it off and almost lost the tiny white plunger). However, I cleaned the relay with fine sandpaper and put it back together (minus the cap). With some dexterity, I managed to refit the sensor with the clamping clip back onto the coil.
All working again.
Since my thermal fuses were OK the failure within the sensor was it's realy contacts not making a the circuit (e.g. pitted, dirty etc.). I note that since the 2 thermal fuses are series connected for redundancy (e.g. if 1 fails to open on over temperature, hopefully the other one will).
Posted on Sep 30, 2009
  • harrynsally Sep 30, 2009
    Couple of more comments.
    The above repair is not for the faint of heart and requires dexterity the ability to skills in electrical troubleshooting (use of multimeter).
    The ceramic sensor is a thermal switch and not an electrically operated relay.
    Be very careful to note how the internal pieces go back together (e.g. order and direction of surfaces) for it to operate properly when repaired.
    When the sensor is cold, it will pass current (the switch contacts are closed) and when it is hot, the domed metal dia-fram changes shape and pushes the small white plastic plunger down, opening the switch and circuit).
I took the device apart and it is a thermostat switch. The contacts were burnt but closed and no continuity. The contacts were fried from high current. I did a search and one guy had a wire harness for a similar B&D coffee maker, I asked and he replied that our thermostat and/or wiring harness was not available. To keep this problem from happening on our present B&D Coffee Maker I shut it offf when I make another pot so the thermostat does not flash closed from the cold water. The high current is handled by the relay on the circuit board and the delicate contacts don't arc when closing. Lesson learned.
Craig
Posted on Jan 27, 2008
    Genius:
  • 1,554 Answers
Http://www.alliedelec.com/search/ProductDetail.asp?SKU=935-0147&R=935%2D0147&sid=479BC9803385E17F
thermal cutoff fuses are rated by temp.
    Problem Solver:
  • 5 Answers
The problem with most all coffee makers is the thermal switch that at abt 400 deg f opens and allows the heater to cool closing the contacts cycling over and over. The current is about 10 amps and eventually the contacts weld closed and bingo the heat rises and blows the thermal fuse. I am working a design that will transfer this load from the thermal sw to a relay capable of handling the current.It's on the drawing board folks and waiting for a test ckt . The thermal fuses are available at Radio Shack.
Posted on Nov 28, 2010
  • technicrat Nov 29, 2010
    This is the schematic of the mod. It has been bench tested and working.
  • technicrat Dec 01, 2010
    There Is an error on the schematic the wire going from the relay NO contact should go to the Common contact. Sorry about that.
Is there a recall on bunn coffee maker model number btxb
* Element or thermal fuse blown. Check for warranty and replace.
Call your vendor.
Aloha, ukeboy57
Jan 12, 2017 | Bunn Coffee Makers & Espresso Machines
Bunn coffee maker heating element wont turn off
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Apr 13, 2013 | Bunn CWTF 15-3 Coffee Maker
My black and decker coffee maker will not turn on to brew coffee
All coffee-makers are provided with a thermal fuse located near the heating element and in series with the element itself.
This device is bullet-shaped with one lead connected to the case, the other insulated from it.
If there was no protection of this kind, it could lead to a fire if the heating element fails to get turned off when reaching its design temperature and nearly impossible to buy as a replacement part.
These are not user replaceable and both the thermal fuse and the bimetal switch that controls the current for the heating element have become increasingly less reliable as they are made in China and since we have little alternative, we have to either keep track of our warranty or just throw it away when it fails.
The fuses can fail at any time and I have brought back three coffee-makers in a five day period, all with the same failure, before giving up and getting a refund.
Another type of failure, namely of the bimetal switch occurs over time and reveals itself by the ever-longer brew time that is unaffected by dissolving the lime in the system.
The heat sensitive metal switch part becomes gradually less responsive causing the machine to just cough instead of pump as when new.
The last one I tossed had reached 40+ minutes per pot.
Nov 27, 2011 | Black & Decker Coffee Makers & Espresso...
We have a Black and Decker ODC440B under the counter coffee maker and today it just stopped working. We love this coffee maker because of how compact it is and it fits perfectly. Do you thinkn there is...
Use your phone book or online yellow pages to search for a repair shop in your area. I suspect a thermal fuse has blown in your unit. Only an experienced repair tech can replace it. Sometimes, the cost of the repair is more than a replacement appliance.
Nov 02, 2017 | Black & Decker SpaceMaker ODC440B 12-Cup...
Are the thermal fuses near the coil or where the
The thermal fuse should be located near the coil. Usually just below the plate, but that all depends on the model.
I hope this helps! :)
Jan 17, 2010 | Black & Decker SpaceMaker ODC325 Coffee...
B& d spacemaker
The symptoms you describe make me think that the brew thermostat OR a thermal fuse has gone bad. I would try to get a warranty replacement, since it is less than 6 months old.
Oct 21, 2017 | Black & Decker SpaceMaker ODC150 Coffee...
NO POWER
there are 4 electrical parts
1 switch
2 thermal switch (keeps heater at around boiling temperature)
3 thermal fuse (will break if thermal switch gets stuck on, to prevent fire)
4 heating element (the hotplate and surrounding tube that boils water)
since the switch lights and hot plate is not hot then it is #2,3 or 4 that is not working.
it is most likeley the thermal switch which is not too expensive to replace.
check the thermal switch by disconnecting it from the wires. at room temperature the thermal switch should be closed. test with a meter set on resistance.
if it is not that check the thermal fuse in the same way, it should also be closed.
if those test ok and the heating element is bad (doubtful) then get another machine and save this for parts
Mar 21, 2008 | Braun Aromaster KF 400 Coffee Maker
Register coffee maker
should be a registration card along with it. if not go to the b&d site and find your machine.
Dec 27, 2007 | Black & Decker (050876530606)
Coffee does not brew
the heater eleiment is bad or the thermal fuses conncting the elements are blown
Apr 25, 2006 | Black & Decker Cafe Noir DCM1400 Coffee...
Black & Decker TCM700 Coffee Maker problem
All coffe makers have a thermal cutoff fuse located on the bottom heating plate. It is usually in series with one of the leads to the actual heater. This should read "short" with an ohm meter. If it is "open" it needs replacement. They are rated in Degrees celsius, and are sometimes difficult to find. Black and Decker may be able to send you one.
Mar 11, 2006 | Black & Decker TCM700 Coffee Maker
Black & Decker (050876530606) Logo
6,155 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
