HP OfficeJet k60 All-In-One InkJet Printer
Problem for HP OfficeJet k60 All-In-One InkJet Printer
There were several jobs in print queue &
By nanjhurley on Aug 17, 2009
there were several jobs in print queue & nothing happening. I shut off printer & tried to
turn back on but it won't.
I unplugged it & plugged back in. nothing. I shut down computer & turned on. nothing.
Best Solution
posted on Aug 17, 2009
Very Helpful)
Lalit999
Rank: Wiz  HP Expert
Rating: 75%, 69 votes
Click on start and go to run than type services.msc, look for "Print Spooler" right click on it and than click on stop and start, then try to print
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
snehathomas
Rank: Wiz
Rating: 82%, 65 votes
Try to delete the printer queue from the computer. try the following steps:
1. Go to 'Printer and Faxes' in the Control Panel.
2. Select the Printer, and double click. you will get a window,which will have the documents in the queue..delete all the documents from here
3. restart the Pc and printer.
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet k60 All-In-One
Questions and Unsolved Problems for HP OfficeJet k60 All-In-One
Do you recommend HP OfficeJet k60 All-In-One InkJet Printer?
Answer
Answer
printer says " busy" when it isn't. can't seem to restore date and time in window
Answer
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple... (More)
Answer
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has... (More)
Answer
How do I scan a document? I am getting a message that indicates that the options are not set.
Answer
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink.... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Van Nuys, CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
