Question about Sanyo DS27910 27" TV
Sanyo 27" Problem: Fuzzy Screen
I have a Sanyo, and when I turn the channel I get a crisp picture, but about 2 seconds after the station is turned the screen is fuzzy. I usually get a little better picture if I run the cable through the VCR, but I am wondering is it worth getting fixed or should i just get a new one.
All of a sudden the tv had a milky screen and diagonal lines through it. what?
Posted on Dec 26, 2007
  • Sanyo Master
  • 5,138 Answers
Sanyo does this alot it is either you need to replace your tuner or you have two resistors 220k ohm s that need to be replaced.this will fix your problem.if repair cost is cheaper to fix then buy a new one its up to on that one!
SOURCE:
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Fuzzy picture
Sounds like an AGC [Automatic Gain Control] problem with its video IF stage circuit. Contact any service technician, or service center. This is not a user repairable fault.
Gopakumar Gopalan Google
Feb 09, 2014 | Sony FD Trinitron WEGA KV-27FS100 27" TV
When i turn the TV to vid1 is has a crisp clear picture but when i turn hit the satellite button it goes to chanel 3 and is fuzzy (grainy looking). Any suggestions? I cant leave it on the vid1 channel...
Get a surround sound system. Run the video to av1, and then the red, and white audio cables to your surround sound aux. You will get the clean picture and great sound.
May 05, 2010 | RCA HD52W59 HDTV Projection Television
No picture on screen
No,Ur vertical/horizontal IC is shorted or cold soldiers.Could be the parts that support the IC is also.
Aug 19, 2009 | Sanyo DS27820 27" TV
Need to know how to set and hold radio stations on a fxd 615 sanyo car radio. will not come on when ignition turned on. when turned on and set channels will not hold
depending on what system you have, all that needs to be done is to select station required and then press and hold a preset button 1-6 for around 2 to 3 seconds and that should store that station
Jun 13, 2009 | Sanyo Car Audio & Video
Sanyo
Go into the setup menu and turn off closed captioning. The black box is a text box for CC. Some stations are sending the signal which triggers the box, but are not actually sending any text.
Mar 30, 2008 | Sanyo DS27930 27" TV
TV CHANNEL CODE
WE JUST GOT A USED TV AND WE ARE TRYING TO HOOK IT UP. THE PICTURE COMES ON BUT IT IS VERY FUZZY AND THE NUMBERS CHANGE ON THE SCREEN BUT NOT ON THE TV. WHAT ARE WE DOING WRONG WE DO NOT HAVE A MANUAL AND IT IS A USED TV WE HAVE CABLE
Aug 27, 2007 | Philips Magnavox 27MS343S 27" TV
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Sanyo DS27910 27" TV Logo
242 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
