Question about Konica Minolta DiALTA Di200 Copier
How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
I'm getting error code C0500 on my Minolta. Your posted fix for this problem was as follows:
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode.
Go to "Counter"
Go to "Trouble"
Trouble reset
If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar.
How do I get to Tech Service mode in order to go the"Counter" and tehn to "Trouble"?
With this error code on the screen all my keys are locked-up.
I appreciate your help & email to "hooman0614@aol.com"
Many thanks in advance.
  • 2 more comments
  • AZAY Mar 09, 2008
    I have an Imagistic IM2520F copier that is displaying code "C0500". Can anybody help me with it.
    Thanks
    AJ
  • Anonymous Jun 18, 2008
    Have the same problem, but when I try to get to the Tech Rep screen it asks for a password (after the sequence)
  • Norman  J Weimar Jr
    Norman J Weimar Jr Aug 13, 2014
    eight 00000000
    if that does not work the maintance provider chg it you will have to enter service mode to reset to default which is 8 0s
    Problem Solver:
  • 15 Answers
I need to know m/c model
Posted on Apr 09, 2009
  • 4 Answers
Power down copier at op-panel.straightend end of paper clip into little hole by op-panel power button.hold in till little dot appears on screen in middle to the left.press #3.that should get you to trouble reset.Or sometimes opening and closing rightside door can reset.
Posted on Jan 04, 2009
  • Konica Minolta Master
  • 6,712 Answers
Also ensure that the right side door is proplerly closed check the plastic latches on the right side door!!!!!! ensure they are not broken cC0500 code indicate that the fuser the hot thing is not getting the 117V-120VAC that is required to heat the lamps. this is because when the right side door is not closing to actuates a sw in front of the machine can not be seen.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Aug 13, 2014
  • 146 Answers
To access service mode:
Hit the utility/counter button.
Touch meter count.
Type the following on the keypad:
<STOP> <0> <0> <STOP> <0> <1>
Posted on Jan 03, 2008
Why can't I enter tech. rep. mode? I followed instructions to enter mode but does not work. I am trying to clear trouble code C0500
You don't use Service mode for a c0500 code on a di151 use the stop button power off the machine hold stop down power on. Then power off then power on if it come back replace the fusing unit the hot part. DO NOT REPEAT reset can cause a fire!
Oct 05, 2014 | Konica Minolta Minolta Dialta Di151F Laser...
Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
Dec 02, 2007 | Konica Minolta DiALTA Di200 Copier
My Dialta Di2011 gives me an error code cof32 service call. What are the likely problems?
COF 32 ATDC sensor failure.Enter in the service mode select Then.rep.mode select printer mode select ATDC gain adjustment note the current value then clear the current value and change the value up or down.Ex: the current value = 150 clear and change to 154 ,make a few copy and if the error code not displayed is OK.If the error code is appaire clear the value and enter 132,make a feww copy,if OK you are resolved a problem.
Service mode entering:
press utility key-press metercount-press details(if apaire the details windows)-press Stop 0 0 Stop 0 1 (if appaure admin code press 00000000 ) select techn.rep.mode-printer etc.
Feb 07, 2013 | Konica Minolta Office Equipment & Supplies
Error Codes
Well the C0500 code is the code that is given when the fusing unit is bad (THE HOT PART) to reset that code need to go to the rear remove top rear cover and press the small black button on the control board lower left. The C0400 is Exposure Lamp the bright lite under the big glass. Might need to get a new one try web site below as for the C0500 if it comes back do not reset get Konica Minolta rep to look at the fuser unit. IT can catch on fire and that would ruin a perfectly good day. If parts required see the web site below for a start Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 16, 2012 | Minolta EP1083 CS/PRO Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
Konica minolta Di3510...C0500 troubleshooting
Go to "Counter"
Go to "Trouble"
Trouble reset
You may need to clear the counter by pressing "clear" and then "end".
After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!"
Oct 30, 2007 | Konica Minolta DiALTA Di200 Copier
Code C0500
simulation = UTILIY -----> METER COUNT (on touch screen)->
STOP------> 0-----> 0------> STOP------>0------>1
Sep 07, 2007 | Konica Minolta DiALTA Di200 Copier
Minolta Dialta Copier
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode. Go to "Counter" Go to "Trouble" Trouble reset If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar. You may need to clear the counter by pressing "clear" and then "end". After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!
May 10, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
4,882 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
