Question about Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 665.17012402 Normal Wash Blinking
I've had my Kemore Quietguard dishwasher for approximately 2 years. I recently experienced a problem where the Normal Wash light blinks about 18 times straight, then hesitates momentarily, and continues the blinking cycle again. When this first happened I checked online for some ideas. One suggestion was to replace the circuit board. I unplugged the original board & plugged it back in & it worked for a week or so. But, then it started the blinking again. My first idea no longer works.
I decided to purchase a circuit board to replace the original. That didn't help. So, I am back to square one. I read also the it could be the heating coil or maybe another sensor. What's my next step?
Thanks!
  • kevlarnovack Dec 02, 2007
    I tried the suggestion of toggling HI TEMP WASH/HEATED DRY for 5 minutes. Nothing happened.
  • kevlarnovack Dec 12, 2007
    I ordered & replaced the entire touch panel. This fixed my problem.
Replacing push button panel also worked for me! Thanks for the solution.
Posted on Jan 12, 2008
SOURCE:
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore Quietguard 3 has mold and is dirty inside
G'day, I have a Miele Dishwasher and I have only had one small problem with it in the 12 years I have own it. That was due to moving house, a bit of fluff had moved and was blocking an outlet. once cleaned with a brush it now works like new again. Best dishwasher on the market, made to last 20 years.
Nov 25, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore dishwasher blinking lights
Dear friend,
ngfam at you service! happy to assist!
The blinking lights are called codes and this is warning you that there is a technical problem. Probably an electronic failure some where. This can only be diagnosed by a trained service tech!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | Dishwashers
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore Quietguard 2
check the water inlet valve first
May 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Dishwasher displays the number "98"
I have a very similar problem. When I push a wash selection, every light on the panel shows up...and when I push Start, nothing happens. When I push cancel, it trys to drain, even tho no water is in there any more. Have you ever had an answer to your problem?
Feb 06, 2008 | Kenmore 16872 Built-in Dishwasher
Kenmore 24 in. 17032 Built-in Dishwasher Logo
300 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
