Question about Sewing Machines
Needle stuck I replaced a broken needle. But now, it seems, the needle gets jammed in the bobbin mechanism and won't go through an entire revolution. Any suggestions?
  • 1 more comment
  • rablbt Dec 02, 2007
    Thanks for your advice. I was afraid it was going to be something like that. But that's what trained mechanics are for. Thanks again!
  • pinotchick Jan 16, 2008
    The needle on my Brother LS-1217 sewing machine just broke. Where do I find a replacement? Jo Ann's, Walmart, any suggestions?!
    Thanks.
  • puppe Feb 07, 2008
    the bobin in my pfaff oes around anymore
    Problem Solver:
  • 12 Answers
It sounds like your machine is out of time. What this means is the hook that grabs the thread from the needle is not coming around at the proper time. Unless you know exactly what you are doing, have a trained mechanic look at your machine. Timing a sewing machine is not something that can be easily explained over the Internet.
Posted on Dec 01, 2007
SOURCE:
Thread jamming in bobbin when i use walking foot
Had a similar problem with our Pfaff. Needed a replacement cam. broken gear.
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Have a brand new Singer 1507 that keeps jamming the bobbin thread. Have followed threading and winding bobbin instructions closely, but am still having problems with the bobbin thread jamming after 1-2...
I would try adjusting the tension on the machine - this sometimes causes the bobbin thread to jam while sewing. Re thread the entire machine including the top thread. Also it is recommended to use new thread as old thread can ball up after time. If no luck I would call the store you purchased the machine from.
Nov 30, 2010 | Sewing Machines
My Pfaf 1222 made a rattling noise, but was sewing. Now it jams with thread after two revolutions, need to hand turn the wheel to get it to turn those 2 turns. I broke one needle. I bent another. When I...
Check the manual for maintenance infromation.
Noise can be from lint in the bobbin area.
After cleaning, re-thread the machine with the presser foot up to see the combination of cleaning and "presser foot up" threading helps.
Mar 29, 2010 | PfaFF Tiptronic 2030
Bobbin mechanism is grinding and seizing up
What you are sewing may be too much for the type of sewing machine you are using.
It sounds like you should use a larger size needle.
The problem with the bobbin could be the thickness is such the presser foot is not down to the position it should be to engage the tension.
When the presser foot is lifted, the tension control opens.
Thread the machine with the presser foot up so the thread can "seat" into the tension control, then try sewing two layers of a thinner fabric to see if there is still a problem.
When you stop sewing to adjust the fabric, make sure the needle is down to hold the stitch in place as you make the adjustment. Movement of the stitch when the needle is up will sometimes cause the thread to jam in the bobbin area.
If the problem continues, the machine may need to have the timing adjusted.
If you are mechanically inclined, you can try this adjustment. Graphics and instructions can be found sewusa.com or take it into the shop for service, which usually begins at around $80. This could be more if you take the machine apart and then cannot get it back together.
Mar 19, 2010 | Sewing Machines
The bobbin is getting caught and needle is jamming
This sounds like there is cotton stuck in the bobbin holder. Check it thoroughly. Take the bobbin out and turn the wheel to lower the needle a few times. This will show up any thread caught. Pull it out gently. You may have to perservere to get it all out.
Oct 19, 2008 | Singer 15ND Mechanical Sewing Machine
Thread jams in bobbin area
well i have done the same thing , all u need to do is if you see the screws that hold the bobbin area you un screwq thoes and get you a pair of scisors and cut around the knoted mess and all you do is work with it until it is all out and you dont realy want to pull on it to much you know just work it around so it gets lose so that you can cut it out thin you put it back together and try it out.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Apr 22, 2007 | Singer 7466 Mechanical Sewing Machine
Sewing Machines Logo
252 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
