Question about Teac P11/KIT Thermal Printer
Teac p11 will not print goes through the motions. cleaned head changed cartridge still not printing
Will not print goes through the motions but does not print i cleaned the head and changed the cartridge and still does not print it is about a year old
    Problem Solver:
  • 4 Answers
Thats retarded..that doesnt work
it doesnt even recognize that the printer exists
and there is no way to get a driver, how am i supposed to make it a deafult printer?
Posted on Jul 26, 2008
Need the software because my disc is to scratched to install
Posted on Apr 19, 2008
First think to do :
Assure that your printer is the default one and the driver is active
After :
Assure your firewall allow the printer software
After :
Verify your cable by trying a new one
After :
Unplug your printer to your computer
Uninstall the printer driver
Restart your computer without the printer plug in
Plug your printer
Leave Windows install the driver by itself
If it cannot
Assure that you have no printer driver install, if yes, uninstall it
Install the printer driver with your CD
Assure the driver is active
Assure the printer is the default one
Posted on Dec 29, 2007
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Replaced ink cartridges, printer goes through all the motions, but paper comes out blank. I have done all the maintenance steps. What gives?
Cannon ink cartridges go into a print head. This is normally a removable box the ink cartridge sits in.
First remove the head and the cartridges from it. Now try this to clean the old ink off the print head, rub/soak the print head in alcohol. Make sure the print head is complete dry and place the ink back in it and return to the printer. Try to print a page, if you have the same results you need to replace the print head.
Jul 21, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I have an Epson CX4800 printer. I have changed all the ink cartridges, but still can not get it to print, it goes through the motions, but nothing prints on the paper.
Try cleaning the heads. This should get the printer cartidges unclogged so the ink comes out. Also are you using epson cartridges or generic. How old are they. If new or quality generic. Its probably the head needs to be cleaned go through that process 2 or 3 times as its much cheaper than new cartridges.
Dec 13, 2009 | Computers & Internet
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Printer performs as if printing yet gives only blank pages
Check whether you removed the yellow strip of the cartridges. remove the upper unit and check when head cleaning the ink goes throw the ink tube. if not you can sure that the head cleaning unit is to be repaired.
Aug 10, 2009 | Epson Office Equipment & Supplies
The printer goes in motion to print but doesn't print anything.
hi
have you tried cleaning the print head? clean it by rubbing the contacts of print head and cartridges with alcohol which should sokve the problem due to clogging or blocking.
you can also use the print head cleaning software to help you.
cheers
Jul 26, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Won't print
printer prints blank sheets
Dec 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
Help
this place is just about as rediculous as trying to find the teac p11/kit driver
Jul 03, 2007 | Teac P11/KIT Thermal Printer
Teac P11/KIT Thermal Printer Logo
252 people viewed this question
Top Teac Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Teac Office Equipment and Supply Expert? Answer questions, earn points and help others
