Question about InFocus In Focus SP-LAMP-021 Replacement Lamp 3000 Hours SP-4805 Projector Lamp
Replacing bulb We've replaced the bulb, cannot reset sttings for lamp hours because the lamp was burned out. How can we reset without bulb being lit.Husband cannot find the manual.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Hold the volume up/down in ,switch unit on while holding these in for 30 secs, if that fails, flash unit with new software.
Posted on May 05, 2010
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Can't reset lamp
Because of this fact, Jasbo, LG has lost all future business from me.
Apr 07, 2013 | LG CF181D Projector
Bought this TV used and was told it needed a ballast board. I spoke with the tech that worked on it and was told a supply board as well as possibly needing a new bulb. I've replaced all three with no...
Sir when replacing the bulb you should reset the lamp hour meter. 1. while on the standby mode press "mute" then the numbers 1,8 and 2 in succession, and press the power button.
2. wait until "loading factory" appears on your screen and the service menu is displayed with the lamp life hours. You will see a list of service options.
3. Scroll down to "option" and press "enter". next you will see "reset lamp" where you will press again the "enter" button. good day and best regards.
  • 2 Wait until "Loading Factory" appears on your screen and the service menu is displayed with the Lamp Life Hours. You will see a list of service options.
  • 3 Scroll down to "Option" and press "Enter." Next you will see "Reset Lamp" where you will press again with the "Enter" button.
  • Read more: How to Reset the Lamp Hours on the TV ' eHow.com http://www.ehow.com/how_5535314_reset-lamp-hours-tv.html#ixzz1VIGJC5k7
    Aug 17, 2011 | Samsung HL56A650 56 in. TV
    Samsung R4266w turns off automatically. I've
    Rest the lamp hour meter
    • 1 Press menu on the DLP's remote.
    • 2 Scroll down the list to "Timer."
    • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
    Service Level Reset
    • 1 Turn off the DLP with the remote.
    • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
    • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
    Aug 14, 2011 | Samsung Televison & Video
    I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
    I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
    Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
    Reset Hitachi Rear Projection Television 50EX12BAV5K022561
    There are no resets. The only way to reset a tv like this is to unplug the unit for several hours and let the memory and capacitors drain before restarting. Have you checked you manual for lamp hours reset and how to change the bulb? These sets need to have lamp hours reset when you change the bulbs or they won't turn on. I might just be possible your bulb has burned out.
    Apr 09, 2011 | Televison & Video
    My pt-ae900u wont turn on. the lamp light is flashing red..and the motor or fan is making a soft scratching noise. I never got any warning on the screen saying the bulb was in need of replacing..but its...
    First of all check the remove the lamp and check the same. if it found burned you have to replace it. Remember one thing you have to reset the lamp hour After replacing the lamp. You can see the option in the menu.
    resetting procedure.
    1. inset the new lamp.
    2. power on the projector.
    3. Press menu and select OPTION.
    4. Press enter button and the select LAMP RUN TIME.
    5. Press and hold MENU button for 3 seconds.
    6. Lamp reset , power off message will display.
    7. power off the projector. this will reset the lamp hour.
    Also Check the lamp cooling fan of your projector. may be its has some problem. its not running at the correct RPM. Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
    ok
    Mar 10, 2011 | Panasonic PT-AE900U Multimedia Projector
    Lamp replaced 1.5 years ago, now the picture goes out but comes back on every few minutes, as if it gets to hot and needs to cool down. Fan comes on.
    Lamps only last for 5,000 hrs -8,000 Playing hrs
    It means every hour you Play TV Lamp burns up the hours, so after 5,000hrs on most Lamp needs replacing, some Lamps dont even last this long DLPs are not like Projection you can play them 24-7 and Tubes will remain good, But Lamps are like a light bulb they all burn out after so many hours.
    Best thing is to turn TV off if you are not watching it, in order to Save Hours burt on Lamp.
    Mats has Lamps for $99.00 1-800-628-1118
    Replace the Lamp.
    Mar 05, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
    TV DOES NOT COME ON
    the light bulb is most likely burning out or lamp hours have set a certain hours and lamp will need to be replaced or lamp hours need to be reset.
    Oct 06, 2009 | Televison & Video
    Can I reset my lamp timer without replacing the lamp?
    That should be fine to do. Even if the projector did alter the current based on lamp life, the worst that could happen in the lamp would burn out completely. A good projector should have a safety circuit with a fuse to prevent damage to any internal components. You should be fine.
    Mar 25, 2009 | InFocus IN72 Multimedia Projector
    349 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    neOen
    Level 1 Expert
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
