Question about Sony VAIO VGN-TX850P/B PC Notebook
VGN-TX850P/B Display Problem
Hello:
My Sony TX850P/B will not backlight. The image is barely visible but it's there. Does not seem to be an inverter or fluorescent backlight in this display. LED backlighted? Can this be fixed without replacing the entire display assembly?
Many thanks for your attention.
Cheers,
Frank
Canada
  • 3 more comments
  • sicilianu Dec 02, 2007
    Many thanks, Romeet. I think you have pointed the way to a solution. I have opened up the display and see a circuit board on the bottom of the screen. The fusible resistor or inductor must be in this board, but I don't know what it should look like. Any tips on how to identify and test it? I have a multi-meter and some basic tools. Again, thank you. Your advice is very much appreciated.
    Regards,
    Frank
    Hi Romeet,
    Again, you have pointed the way. It's midnight and snowing heavily here in Canada, so I'll open the display tomorrow and follow your instructions for testing. May need to send you a photo of my circuit board if I get stuck. Many thanks for your patient advice.
    Best Regards,
    Frank
  • sicilianu Dec 03, 2007
    Hi Romeet,
    I checked the continuity of the two lower components at location 1 and both "beeped" my meter (<30 ohms, test current <0.7mA). Same with the top component in location 2. None of the components are marked "F" or "L". I assume the beeped components are fuses, I checked all the others that looked similar. These must be capacitors and resistors. If there is a blown fuse, then I may have missed it. Only good thing here is that it has stopped snowing outside.
    Thanks and Regards,
    Frank
  • Anonymous Apr 02, 2008
    HI there Romeet, I have a Vaio VGN TX850P . I originally damaged the LED screen and ordered a new one on line. When i installed the new LED the backlight will not come on . You can tell the text is up fine, there is just no light. (I am worried that even though the laptop was off, i needed to remove the battery? I fear this is the case. Would that have blown a fuse?)I went inside to check and make sure the LED cable coming from the main board was seated properly and it appeared to be fine.
    Would it be best to replace the invertor board at the bottom of the LCD if I dont have tools to fix a fuse? If so, where can i purchase this board or do you know a part? After hours of searching i am so happy to have found this blog.. you have no idea.
    Thanks, Susan.
  • ciccino46 May 03, 2008
    I have same problem with my TX850P/B as Susan. Display suddenly went blank. Could see the text up faintly but no back light. Bought a new display online and replaced the old one. Problem persists. Anyone out there know the cause? Thanks. Ciccino.
  • 66 Answers
Hello Frank,
This is Romeet, id like to try and help you.Most Sony's have a small circuit at the front end of the LCD that effectively works like an Inverter Circuit.How good are you at opening these things up? any electronic repair centre near you? has to be a problem with the fusible resistor or inductor on the circuit i mentioned ( as mostly seen in my experience ).Please let me know.
B.Regds
Romeet
Posted on Dec 01, 2007
  • Romeet Barmeda
    Romeet Barmeda Dec 02, 2007
    Hi Frank,
    Good, your interest in electronics might help.Refer to picture above, your fuse or inductor most probably lies in spot marked 1. A fuse is mostly indicated with an "F" and a number indicating the number of fuse in that circuit,for eg F3 means its the third fuse in a circuit with atleast 2 more somewhere else. If you do not find the fuse in spot one, check for it in spots 2,3,&4 .An Inductor is indicated mostly by an "L" eg L1 or L3 etc etc
    In the picture above, the fuse is the top one indicated by F1 ( closely followed by capacitors C3 & C5 ) i guess the one in your circuit should also be lying in the same spot.Maybe you could try taking a snapshot of it and sending it to me incase it gives you a hard time spotting one?
    Once you have located the fuse / Inductor.. Put your multimeter in "continuity checking" range just like you would do to check a normal fuse.Test the fuse, if it has shorted out, check up the rating of the fuse indicated on its top and get a fuse wire of the same rating and solder it onto the fuse ends.
    Hope this helps, let me know.
    B.Regds
    Romeet
How do i replace the backlight on my sony vgn-fj1s
It's much easier to just replace the screen than trying to replace the back light. Save yourself the trouble and buy a new screen on ebay.
May 02, 2012 | Computers & Internet
My Sony VAIO Laptop screen is black. It worked fine, no issues2 days ago. Went to turn it on last night and it is black.. When light hits at a certain angle, I can see the desktop, I can hear the startup...
A faint and barely visible image on the screen indicates that the backlight(s) that illuminates the display isn't powering on. A device called an inverter board takes DC power from the laptop motherboard and converts it to AC power to power the screen backlight.
Before attempting anything below, be sure and remove the laptop battery and unplug the laptop
You need to take the screen apart and check to make sure that no cables are loose that are connected to the inverter board. If everything is secure, the next thing I would do is try to test the inverter board by hooking up an LCD from another laptop to the inverter and turning the laptop on to see if it lights up. If the other screen does light up, then the inverter board is likely good and your backlight needs to be replaced. Backlight replacement, unfortunately, can be very tricky for even an experienced technician, and many will opt to just replace the entire screen.
If you can't test the inverter board, then it might be worth it to order one and see if installing it fixes the problem.
Youtube is a great place to check for instructional videos on laptop repair, such as this one:
http://www.youtube.com/watch?v=jjXLR5yY7X4
Sep 21, 2011 | Sony Computers & Internet
No image is coming out of its LCD. It's diagnosed to have damaged video chipset. It seems its cooling system is inefficient. model: Sony VAIO VGN-CR131E
Hi
Who diagnosed it?
If the surface of the "video chipset" (graphics chip) is damaged it may be possible for a specialist, with an Infra Red Workstation to repair it:
Ball Graphics Array Reflow
or
Ball Graphics Array Reballing
These repairs can be expensive and the fault can come back after repair.
But it might also be a fault with the LCD Panel, the Cold Cathode Backlight or the LCD Panel Power Inverter.
Connect the laptop to an external desktop monitor with a VGA cable, using the Fn + F5, F6 or F7 button to send the image to the external monitor. If no image appears, then the fault is with the graphics chip, if you get an external image then the fault is with one of the other components I mention above.
I hope this helps.
Aug 26, 2011 | Sony Vaio Vgn-cr131e/l / Vgn-cr120e/l /...
Hi my sony vio vgn txn 15p video is faint
If when you say faint you mean you can barely make out an image then the problem is most likely the backlight inverter in the screen assembly has gone bad. If what you mean is that the brightness got turned all the way down then it's just a matter of adjusting the brightness of the screen by holding down the function key (Fn) and pressing the LCD screen brightness adjustment keys noted usually by a picture of a sun or something similar accompanied by an up or down arrow.
Dec 09, 2010 | Sony VAIO VGN-TXN15P/B Notebook
Can't see the Image
Can you see the image on an external monitor? If so, then you need to brighten the screen using the function keys on the keyboard. Or--the backlight or inverter have gone out on you and will need to be replaced.
May 12, 2010 | Sony VGN-BZ560P34 PC Notebook
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
The screen fades out sometimes and i have to wiggle it to get it back. i have a sony vaio vgn-cr115e
www.ladparts.net
Oct 19, 2009 | Sony VAIO VGN-CR115E/P Laptop
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
I'm using a vgn nr220e series laptop and i had problem with my scree. its turning on but the screen went just blank..i try rebooting it but still nothing hapens
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 09, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Laptop screen flickers and goes off .
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Picture flickering with dim display.
Apr 13, 2009 | Sony VAIO VGN-C140G/B Notebook
Sony VAIO  VGN-TX850P/B PC Notebook Logo
285 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
