Question about Lexmark X3470 All-In-One InkJet Printer
Won't scan at all
Every time i try to scan nothing happens. I want to know how to scan
  • 2 more comments
  • myna102 Dec 02, 2007
    mine won't scan either it used to, this is the last time i'll buy a lexmark this is my thire
  • MC87 Dec 10, 2007
    same damn thing why doesnt it work
  • msblaque Dec 10, 2007
    it won't scan
  • Anonymous Dec 18, 2007
    it wont scan
    i dont know what to do
    Problem Solver:
  • 11 Answers
With all of you having the same problem, it doesn't sound too good. Just to cover all bases (have to do that in troubleshooting) do you have compatible software installed for the scanner to work with? The scanner needs a program that will recognize it. What program is this? it may help me to help you if I know it. Can you try opening that program and telling it to scan from there, rather than from the scanner?
Posted on Dec 17, 2007
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
Apr 10, 2012 | Canon Office Equipment & Supplies
Won't turn on.
Did you get it working Jason? My MP610 did the same thing to me this morning... I went through all the rigmarole of moving it, testing it with different power cords and etc... with no success. I left it unplugged completely, tried it again this afternoon and it works. Well, it turned on, copied a piece of paper, I was able to access the ink cartridges and switched it on and off again twice and it worked. Hoping it will stay that way.
I don't know if it happened because I put a CF card in to slot - will try card in another reader first and see what happens...
I would be interested to hear what happened with yours, Jason.Cheers, Vicki 23rd April 2012
Feb 20, 2012 | Canon PIXMA MP610 InkJet Printer
I replaced my battery and the radio does not turn on nor do the head lights. All fuses are fine. The lights show if i want to flash the brights. But nothing steady. I even replaced a bulb with no change....
Well, I guess you won't be using the radio or driving after dark
You will get the code when you spend something,
because without the scan tool it won't happen.
Jun 10, 2011 | 1996 Hyundai Accent
Hi there we have a 2001 Z22 cavalier and the fuel pump kicks on but when you go to start it all you here is a loud whining sound and it won`t start and when it was running at times it would lose its power...
when you say it wont start does the engine crank (spin over and over) but not start? if this is the case then the most common thing that come to mind with the fact that you said it would loose power and die then i would have the crank sensor tested, but this problem only happens every so often so the crank sensor may test good , i would try and replace it and the next common thing is the control module. ive had a few of these with the same problem and they needed the crank sensor and the ignition module replaced, i cant say yours is the same but you have to start somwhere, the tech ,has he scanned the computer to see if there are any codes? and last let me know if this car is spinning trying to start or does it do nothing when you try to start it but the whinning noise, this is important to know, good day.
Apr 12, 2011 | 2001 Chevrolet Cavalier
I hit scan button and nothing happens
try on the program or the application software on your pc, some times the configuration cant let you scan, print or copy from the devices directly, if choosen the scan and nothing happend either then you have serius situation because could be a conflict in the driver that make you see the device but dont use it... try with the software, if you can use it, then search in the option menu for the config adecuated to use the device on the program and manually
Aug 16, 2010 | HP Office Equipment & Supplies
I had to get a new battery and now my dvd player will not work...this seems to be happening to other folks as well. Any suggestions? I know if I take it to the dealer, they'll just want me to buy another...
This is just a thought, may not be the problem, but in most modern cars they tell you not to remove the battery lead for a long time, If you took a long time to replace the battery that may have reset some of the computer settings,
To reset them you need to scan the system which means the dealer. Sometimes you can get a free scan at Autozone, worth a try.
Jan 18, 2010 | 2006 Honda Odyssey
It will not print. It will scan. It says it is ready but nothing happens.
Solved: Printer Will Not Work Tip: Click here to scan for System Errors and Optimize PC performance .... i will try that but now i have another problem. i know what i am typing ... the restore, nothing happens for minutes. i end up closing it. ... I then opened a Word Doc, and when I clicked print, ...
forums.techguy.org
Dec 04, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Jun 05, 2009 | Lexmark X6570 InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
