Question about Whirlpool GEW9250 Electric Dryer
Duet dryer When I press the control on button, the amount of time will show but when I press the start button, it just beeps and does not start. What could be wrong?
  • 2 more comments
  • coasty Dec 08, 2007
    same here, my dyer is an GEW9200LQ0 (4.5 yrs old) and it doesn't start, the sensing light comes on and thats it...
  • RCcola Dec 13, 2007
    Same thing here. I've tried unplugging it, and pushing all of the buttons in different combinations. All the dryer does is beep at me!
  • Anonymous Dec 23, 2007
    beeping not starting
  • Brodeur Jan 02, 2008
    Currently the lights on the control panel come on by themselves, it will not allow you to cancel out. It does allow a reset when I unplug the system overnight, but that does not always work either. Sometimes if you run it through the sequence it will shut off, but then again it doesn't always work. The dryer was purchased in Nov 2005, single user in home, so it has not done a lot of laundry. My best guess control board faulty!!!
    Problem Solver:
  • 17 Answers
Try this link and input your model # this will give you the service manual on your unit
http://servicematters.com/docs/wiring/wiring_main.htm
Hope this helps
Posted on Dec 10, 2007
SOURCE:
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Have Duet front load dryer. When pressing Hold/start button, hear 3 fast beeps from the back of the unit, display flashes and dryer will not start. Any suggestions?
This is a common problem with the Duet and the solution is to replace the Motor Control Board (MCU). The control board has a short and the new control boards are revised to address this issue. Here is a link to the new control board.
Here is a copy of my service manual to help you replace the control board.
Good luck and keep me posted.Richard Roth
Oct 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
Whirlpool duet gas dryer. was working fine now all light and time amount work but will not start and beeps 3 times
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet dryer control lock mode
press and hold the control lock button until you hear a beep. should take about three seconds
Mar 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GGW9200LL1 will not start
The electric flash does not sound cool, It sounds like you have a door switch problem. Check to see if the door switch button is in tact. If it is , you may have to go after the door switch itself. Try this, press more time, less time, more time, less time buttons in that order, the whole panel should light up, open the dryer door, you should hear 1 beep and OE displayed, If you have this the door switch is ok, Catriver
Jan 14, 2009 | Dryers
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
299 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
