Question about Brother XL-5340 Mechanical Sewing Machine
Brother XL-5340 sewing machine
Will not sew just keeps breaking thread. I tried changing the bobbin and thread and cleaning out the lint inside but nothing works can you help me?
  • nana katie Dec 01, 2007
    Tried a new needle and tension adjustment, doesn't seem to help.
I have the same problem! except mine doesn't break thread, it just comes out. Oh, mine's a ELNA Transforma
Posted on Nov 16, 2008
    Problem Solver:
  • 12 Answers
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Posted on Dec 01, 2007
  • Tim Krueger Dec 01, 2007
    What material are you sewing on? Does it happen with any material? I'm going to assume the thread is good quality, not Walmart 5 for a buck stuff, which is HAND thread, not machine thread. Also, please make sure the needle is correct for the type of fabric youre sewing on. One other thing I would recommend, without seeing your machine is remove the needle plate from your machine, and with a FINE emory board LIGHTLY "sand" the area around the needle hole on both sides of the plate. Through use, sometimes the needle flexes and hits the edge of the hole causing slight burrs. They can grab the thread and tear it.
Bobbin thread cluming up
Make sure you have a tight wind on the bobbin, and it is free and clear of any lose threads. Also if replacement bobbin make sure the size is right for machine model. To thin of one causes them to bounce up and down putting tension on thread as it is sewing.
May 22, 2015 | Brother XL-5340 Mechanical Sewing Machine
I've a Brother XL 3500 sewing machine and when I
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 11, 2013 | Sewing Machines
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Thread keeps breaking
change the needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin
Check tension 3 or 4 is usually good
Nov 21, 2010 | Brother XL-2600
Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Apr 21, 2009 | Brother XL-5340 Mechanical Sewing Machine
I have a Brother XL3010 and I can't get the tension set right. The bottom thread keeps making loops. What am I doing wrong? thanks stampinjean
try and adjusting your bobbin case tension ,the little screw on the bobbin case. with bobbin in case hang by thread if it drops easy tension is to light cotton should be able to slightly move through the case. hope this helps reguards
Feb 26, 2009 | Brother XL-5340 Mechanical Sewing Machine
Machine not sewing
Have you checked that the tiny screw in the bobbin is not loose, sometimes this creates this problem for me or if the bobbin size is incorrect.
Dec 13, 2008 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5340 Mechanical Sewing Machine Logo
331 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
