Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DUC600XTPQ6 Quiet Partner I
Clean Light flashing indicates the heating element is malfunctioning. How can I fix this myself ??
  • ttragale Dec 04, 2007
    Model GU2400The clean light is flashing so I changed to heating element, but the light is still flashing. Am I to reset this another way.
  • Anonymous Mar 17, 2014
    Whirlpool quiet partner v heated dry doesn't work
  • 447 Answers
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Posted on Dec 23, 2007
  • dennis Sep 18, 2013
    thank you had a problem changed heating element light still on did the reset works fine now thanks alot
The sequence of pushing the buttons just fixed mine!!! It's finally working, however, it still doesnt wash as good as it use to. What else can I do?
Posted on Jul 08, 2010
  • seejaysevin Jul 08, 2010
    How do I replace the heating element?
Try the door switch! Take the metal tab that the door latches on to and bend it down just a little. This fixed my problem! Push on the door when it closed to close it tighter. If you here a click, and then another click when you release the pressure then the switch could be your problem.
Thanks to 'the dr' I fixed my machine. I have been trying to fix my Quiet Partner III for months now, I knew it had to be something fairly simple, because it appeared to function fine except for the heating element, which I was not sure was working. I had to keep clearing the fault to get the machine to run, but it always stopped short and gave the blinking clean light. I read lots of posts about the possibility of the heating element being bad or the contol board, but this was the first one I read that mentioned the door switch, I had assumed that there was just one switch in the door latch. There are in fact two. One for everything except for the heating element and one for the heating element. When I pushed on the switch in the door, I could hear two clicks, one right after the other. If I pushed the door in a little harder, after the door was closed, I could hear the second click which promptly unclicked when I relieved the pressure. I knew then that I had found the problem. Bending the thin metal piece that the door latches onto fixed the problem!
Posted on Jan 19, 2009
Whirlpool quiet partner ii clean light flashing 7 times. I installed a new heating element and reset the code, and it still flashes 7 times
Check the main control for the heater relay, this may be faulty and the cause of your issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 30, 2016 | Whirlpool Dishwashers
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,037 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
