Hi my acer aspire 3050 screen shows the blue backgroung of windows when you start it up but now its got fine white lines running through it, it you moved the screen back woods ect you could then get a clear viewing screen but then if you touched the screen it would go and where you type the password it would move up screen, not sure if I need a new screen and if its worth repairing, dont want to buy a new screen and find out the screens ok and its something else. Hope this makes sence, Regards chris
Hi, It sounds more like a problem at the inverter end, probably dry
joints on the coil or a cable has disconnected from it. Either way you
will have to remove the screen bezel (plastic screen surround) to get
to the inverter. The inverter is an elongated circuit board under the
screen itself, just check that the cables are connected, if they are
disconnect the cables and remove any screws holding the inverter to the
lid and take it out. Look at the back of the inverter for the coil
(it will have copper wires coming from it) and re-solder the points
around the coil, put back the inverter and connect the cables to it and
turn on the laptop. You will probably find the display works fine and you can re-assemble the screen bezel.
HI - MY ACER ASPIRE 3050'S SCREEN JIGGLES. Just started happening 2 days ago. Now sometimes the...
(More)
HI - MY ACER ASPIRE 3050'S SCREEN JIGGLES. Just started happening 2 days ago. Now sometimes the screen freezes and / or the screen gets too white for about 10 seconds then comes back to normal (but still jiggles). A techie told me it is probably a $30 part that needs replacing (he said it was a pretty common problem) but he didn't describe the part or the process too well. Some kinda linkage from the motherboard to the screen. He said that if I connected my laptop to an external monitor via VGA or whatever, and if there were no issues, that would suggest the linkage problem. Otherwise, maybe the motherboard had a problem. HELP!!!!
i want to restore me factory setting on me acer aspire 3050 on vista but dont no what to do once ive...
(More)
i want to restore me factory setting on me acer aspire 3050 on vista but dont no what to do once ive pressed alt and f10 can you help me thanks
