Hitachi 65xwx20b convergence
Replaced stk392-150 i.c. convergence on blue gun still wont move checked all resistors ok convergence was working before replaced stk but blue was way off then blue locked up and wont move vertical so replaced stk still locked up
  • chad c Dec 01, 2007
    replaced stk392-110 and 392-150 thats the way they came from factory. before replacing stk's the convergene was misaligned we were able to adjust all 3 colors back to alignment then we shut off for the night woke up and convergence was way off again (forgot to save to rom) started adjusting all colors back to convergence lines were not wanting to adjust very easy bouncing back and fourth then lines started pulling apart then blue locked up and were not able to adjust side to side any more every thing else still adjusts. which resistors control side to side fo blue gun.will go back and recheck ohms. any way to check voltage on stk? any way that blue gun can be out of convegence so bad not able to adjust in maual or service mode? thanks for answers.
  • chad c Dec 02, 2007
    chad c- e-mail-l
    laurawoelmer@yahoo.com
    Novelist:
    Champion:
  • 232 Answers
Your message says you "replaced stk392-150", did you replace both of the stk`s or just one of them??? One is for RGB vertical the other is for RGB horizontal, you should always replace both stk`s as a set, Hitachi recommends you use a "replacement kit"
part number X480306", this kit includes both stk`s with a new & supposedly improved set of stk`s as well as all resistors that are required for proper set-up, they strongly recommend you change all of the parts in their kit. The only other thing besides IC`s & resistors that could cause your problem is:
1) bad dcu output (you need a scope to check this)
2) you`ve lost either the +15 volt line or the -15 volt line to the IC`s, "Fxxx" chemical fuse open in power supply.
Posted on Dec 01, 2007
  • Larry Eastman
    Larry Eastman Dec 01, 2007
    Chad, send me your email address & I`ll send you the info you need in a pdf bulletin.
My 6 year old 65xwx20b tv convergence problem
Good Day,
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, www.bdent.com and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Needs convergence IC's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Good Luck,BIG IRISH.
Nov 23, 2009 | Hitachi Director's Series 65XWX20B 65"...
Can't get manual conf. to hold in white
Ur convergence it dead.need it to be replaced,know how to solders?Tries these Websites for convergence kit.Tv repair World.com or Tv repair Kits.
Nov 18, 2009 | Hitachi Director's Series 65XWX20B 65"...
Blue lamp is not in focus
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 05, 2009 | Hitachi 46F500 46" Rear Projection...
12 years old rear projection, the blue + won't move left
First check that no resistors are burnt near the convergence ICs, of course with the back open. Next tap on the metal heatsink and see if the blue pops straight, if it does you could just solder the pins on the IC nearest the blue convergence yoke plug, soldering is a trained skill and would involve pulling the chassis back and flipping it upward without breaking any wires or components. If you see discolored resistors in the right section the ICs are shorted and need replacing.
If nothing is loose and everything looks OK, you may have a bad remote button (probably not, but hey) . as a last resort you could try moving the blue yoke centering tabs, this would move all the blue at once so if its bowed anywhere it would not solve your issue. If this helps great , if not post more info for more help.
thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 17, 2009 | Hitachi Televison & Video
Not able to adjust red convergence on top or bottom
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Hitachi 65xwx20b
hello. yes you might check the cord . ? or your outlet that your pluging in to,might not work.? check them. ok hope this help's you."GOOD LUCK"
May 03, 2008 | Hitachi 50UX58B 50" Rear Projection...
Auto focus convergence on blue doesnt' work
this is an idication that eather the convergence ic's or convergenc ic output resistor have blown
Feb 16, 2008 | Samsung HCM422W 42" Rear Projection...
The BLUE crosshair will not focus,
go here
this is for sony but your should be close enough. you want to manually focus the blue gun.
please mark post fixya!
Feb 11, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Hitachi
You have bad convergence IC,I'm afraid. You will need to have both of them replaced. this job should run you about 300 bucks or so to have them replaced and the set realigned. DO NOT try to adjust the convergence inside of the set before replacing the IC's, as this will only make the job cost you more. Good Luck
Jun 19, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
372 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
