Question about Sony Handycam CCD-TRV37 Camcorder
Error code c:21:00
What does that mean, it just keeps ejecting the tape??
I have the same problem and it is fixed! I laughed when I first read this but it does work! Take off your battery from the back of the camera, turn it over and give it a nice firm wack. Put battery back in and it WILL get rid of your error and work. I've tried the hair dryer before and it has worked but this time for me it did not.. It truly works... Hope your as happy as I was when it worked....
Good luck..
Bob
Posted on Jan 01, 2008
  • 169 Answers
It means your camera is detecting moisture that why c21:00 is appearing then try to warm the camera using a hair blower you should open the lid cover of the mechanical.......... turns off the camera and unplugged the ac adaptor..if you using the battery take it out ... then place your hand to the mechanical to sense the heat of the camera when you using the hair blower and when you feel too hot then stop the blower.... doing this must not exceed 10 second...... then wait at least 1 minute to cold down the camera and put the adaptor or the battery then power on the camera.... if you doing this and nothing happen....i suggest you to go to the service center for replacing the dew sensor....
Posted on Dec 09, 2007
    New Friend:
  • 11 Answers
Hi, intro in https://www.youtube.com/watch?v=KhzD7Xf5Rso
Posted on Apr 11, 2013
How to eject an HDCAM tape stuck in as BVW75 Beta deck.
I don't know what this error code means but I have managed to remove tapes which stuck in a VCR and cannot be ejected. Whether you do this is purely up to you, but it's usually possible to remove the casing (carefully!) so that you can get to the tape-handling section. Then it's a matter of gentle probing & trial and error to get the machine to release its hold on the tape. Look for a series of mechanically linked parts which are driven by motor but activated by a microswitch tripped by action of inserting the tape. Just don't strain the linkages and if you remove anything make a note of where it came from.
Apr 28, 2015 | Televison & Video
I have a GR-AX820 VHS. I'm getting error message EO3 and the tape keeps breaking. What do I need to do?
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!)
Jul 09, 2008 | JVC Televison & Video
AIT-3 Tape Ejects when they put in MSSQL 4027
You will not find the list of the error codes on the internet. I know that Error Code: 0x81 is a "Reel" problem as I was just told by Sony Support. You should call them, have you serial number at hand when you do so. Check http://sony.storagesupport.com/ for a Telephone contact number.
Good luck, Bruno
Jul 15, 2011 | Sony (LIB81A3BB) AIT-3 Tape Drive
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
EZECTING TAPE LOADER
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Mar 28, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Feb 29, 2008 | Televison & Video
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Oct 17, 2007 | Sony DSR-45 Mini DV VCR
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Sont DCR TRV16
Smack it!!
And have a look at www.camerahacker.com
Aug 14, 2007 | Sony Handycam DCR-TRV16E Mini DV Digital...
SLV-660HV Will not load
If you removed the tape carriage assembly, gear timing is probably off, assuming it is gear driven. Being one tooth off will prevent things from working properly. Gears will often have a mark (like an arrow or dot) which must be lined up with each other, in a mode specified in manufacturer service literature. Another possibility is sensors. There are sensors (usually optical) which tell the logic when the tape is properly loaded. If one of these is broken, or otherwise non-functional, logic circuitry will go into error mode, and, in this case, eject tape & display an error code. Lastly, check your mode switch. This tells the logic what position the mechanicals are in (gears/levers/slides). Again, if this is awry, you will have an error condition.
Jun 04, 2007 | Sony SLV-660HF VHS VCR
Sony Handycam CCD-TRV37 Camcorder Logo
639 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
